Engine spins but wont start help - Page 12 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #166 of 193 Old 12-29-2018, 03:03 PM Thread Starter
Re: Engine spins but wont start help
Originally Posted by Whirly View Post
clearance is set with a 'feeler gauge'.. it's in the range of 0.04 for one.. the other is different.. I do not know the exact ##.. this past summer I had to do my 'V' twin 20 HP.. it's tricky to get the adjuster torqued right.. I didn't use a torque wrench to do that.. ya have to hold the adjuster then tighten the lil nut.. ya can't use a socket to do that..
I saw that in a video and it was a torx screw but his was 16 hp and mine is only 12.5.
I actually have torx sockets I can easily attach to my torque wrench. He did say the clearance should be between .03-.05 though so .04 sounds good.
Edit: Actually he said thousandths so would be .003-.005? idk maybe I will try to contact briggs for exact specs.
stangone5o is offline
post #167 of 193 Old 12-29-2018, 05:50 PM
Spindley
Did I see correct. In one of your posts the engine hesitated when you tried to start it. That’s a red flag. It seems your valves aren’t adjusted properly. We all know it runs but still backfires. Is that correct?
SPINDLEY is offline
post #168 of 193 Old 12-29-2018, 05:55 PM
Spindley
I can help you out if you give me a pic of your model, type and code. It’s stamped on the valve cover. No need to call Briggs. I got 20 plus years in this business. Trust me. I do this for a living.
SPINDLEY is offline
post #169 of 193 Old 12-29-2018, 07:22 PM
not quins. but sextuplets
Whirly's Avatar
Originally Posted by SPINDLEY View Post
I can help you out if you give me a pic of your model, type and code. Itís stamped on the valve cover. No need to call Briggs. I got 20 plus years in this business. Trust me. I do this for a living.
SPINDLEY said he can help u a lot.. take his advice.. I will set on the sidelines & offer advice from there..
the round fenderd JD's
total tractors is 30..
Whirly is offline
post #170 of 193 Old 12-29-2018, 07:52 PM
Spindley
With all do respect Whirly. I will still take any suggestions. Two heads are better than one in this case.
SPINDLEY is offline
post #171 of 193 Old 12-29-2018, 09:52 PM
Here is a couple of links from this site so as you can download a FREE Briggs SErvice manual for your engine.
The second one is a direct link for your engine instructions. See page 21. Their are also several you tube videos of such.
A hint that your valves may need adjusted, especially the exhaust valve is the compression hang-up at TDC when cranking the engine.
Listen to SPINDLEY, he can help you. I'll sit on the sidelines with Whirly and listen.
These links may work best when using google chrome.
Links to download free Briggs Service manuals.
https://www.mytractorforum.com/280-s...r-manuals.html
https://drive.google.com/file/d/0B6N...o3azl6OUU/view
Forest Gump is offline
post #172 of 193 Old 12-30-2018, 01:21 AM
Whirly's Avatar
that was my thought too.. even the 2 heads..
Whirly is offline
post #173 of 193 Old 12-30-2018, 12:13 PM
Usually briggs has the decompression on the intake valve.
38racing is online now
post #174 of 193 Old 01-01-2019, 05:33 PM Thread Starter
Hey guys thanks for the info and links, I will take a look at those.
I had the mower out today to get the last of my leaves. I had to charge the battery but then it started right up and I didnt have any issues. It still sounds pretty much the same as in the last video I posted but i dont know if thats good or bad. There was not any loud noticeable popping backfiring happening but maybe a small faint pop here and there.
Do you guys adjust valves as part of maintenance or only when needed?
This mower is 12 years old and they probably have never been adjusted so either way I figure it wont hurt to check them and adjust if needed and see how she sounds afterwards.
@SPINDLEY... Here is that stamped information...
Model-219807
Type-0147 E1
Code-070521ZA
post #175 of 193 Old 01-01-2019, 07:02 PM
Whirly's Avatar
Model-219807
Type-0147 E1
Code-070521ZA
in a manual I saw years ago B&S said to readjust the valves every three years.. I have not seen that in the current manuals.. B&S deleted that info..
Whirly is offline
post #176 of 193 Old 01-01-2019, 07:50 PM
Slightly Autistic
Bill Kapaun's Avatar
It's in the Owners Manual under "Maintenance".
Kind of where one would expect it to be.
Yearly for this engine, although that is probably overkill for average use.
See attachment-
Illegally Blind
Bill Kapaun is online now
post #177 of 193 Old 01-01-2019, 08:02 PM Thread Starter
See attachment-
Well thats good to know. It is not listed in my craftsman owners manual for the mower, or else I would have done it by now.
I wonder why they left it out.
post #178 of 193 Old 01-01-2019, 08:20 PM
Spindley
Valve setting are as follows. INTAKE is .003-.005. EXHAUST is .005-.007. You want to take your spark plug out and find compression stroke. Then take your valve cover off. That’s the silver cover with the numbers stampings. Now bring the piston on top dead center. The way you know, if you hold your finger over the spark hole you’ll feel the pressure on the upstroke of the piston. You can do this by hand by turning the flywheel. Once you feel the pressure take a piece of wire about a foot long and stick it in the spark hole. This is know when the piston is right on TDC (top dead center). Now your ready to adjust the valves. Intake valve is always the same side as the carb and exhaust is always the same side as the muffler. Not sure of the tools you need,but these probably have a jam nut on the top o the rocker. Losen the nut and adjust to the desired spec. When putting the cover back on use a bead of oil resistant RTV sealant to seal it back up. Put the plug in and fire it up.
SPINDLEY is offline
post #179 of 193 Old 01-01-2019, 08:21 PM
Spindley
Anything I missed there gentleman, please add your comments
SPINDLEY is offline
post #180 of 193 Old 01-01-2019, 08:22 PM
Spindley
Your owners manual is on the Briggs website
SPINDLEY is offline
