753 rat tractor project - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 03-05-2019, 10:27 AM Thread Starter
New Project. We have what i think is a 753. Correct me if i'm wrong please. Tractor probably hasn't run in 2 decades and was missing allot of parts. Don't think the engine is original as it has white, blue and turquoise paint on it and the carb had red and yellow. Its missing all the cables, and hood. Coil and all wiring was gone. We put on a new coil, points, plug, wire, battery cables, and wiring. We tried rebuilding the carb but is was full of dried gas. completely solid clogged fuel bowl. The whole carb is corroded inside. It does start with spray but i don't think the pump is working as it will not throttle up. New carb, pump and parts to make it run on order. We found the exhaust valve stuck. Pulled the head and soaked it good and worked it loose. New head gasket on the way too. Tank is leaking, got a new gasket coming also. My neighbor wants to rat it out. He has a deathtrap pile of parts that someone gave him that has a really cool deep arch to the beam. Its already been flipped to lower that one. Gonna put it on the front of this tractor. Someone created this front axle. looks like someone fabricated spindle mounts. Were gonna make 5" wheel spacers to widen out the rear so the seat can drop between the fenders to get it low.
Update. New carb, fuel pump, tank gasket, and head gasket came. I fixed the governor, the little arm that the throttle lever connected to was broke off so i welded a new one on and hooked up the throttle cable. Make a new bracket for the choke cable and hooked it up. Then......... We cut off the front axle and welded on another. We had a monstrosity that someone previously tried to make a ra tractor out of that was more of a death trap than anything. We cut 7" off of the front and welded it to the front of the 753. Thr front tires are 3" lower and the axle mount is another 2" so the front is about 5" lower than stock. We cut the hood out to fit around the gas tank. We mocked up the dummy fuel tank. We just have to make a hood hinge now and mount the tank.
ID:	2364963   Click image for larger version
ID:	2364965   Click image for larger version
ID:	2364967   Click image for larger version
ID:	2364971   Click image for larger version
ID:	2364973   Click image for larger version
ID:	2364975   Click image for larger version
ID:	2364979   Click image for larger version
indslpwr04 is offline
post #2 of 11 Old 03-11-2019, 11:41 AM Thread Starter
Re: 753 rat tractor project
Update:
We figured out the steering yesterday. I could not get an acceptable turn radius with the steering yoke and tie rods in the original location with the lengthened frame. So we cut the steering shaft, lengthened it and added another support. It has full lock turning radius now. The aluminum tank turned out to be brass. figured out a hood hinge and mounted the hater pipe with flapper. As soon as the wheel spacers are machined we will work on the rear end and get the seat dropped.
ID:	2365969   Click image for larger version
ID:	2365971   Click image for larger version
ID:	2365973   Click image for larger version
post #3 of 11 Old 03-11-2019, 02:48 PM
10,000 +posts!
glenn27's Avatar
Question Re: 753 rat tractor project
Wow--you have done a lot of work from, basically nothing much...
What a nice-well equipped shop--looks o me. And please tell me about that lift table--as it were--details and pictures, plse. Intereseted in that- for sure--
Jimmy Buffett
glenn27 is offline
post #4 of 11 Old 03-11-2019, 04:28 PM
Hahn Star
MikMan48's Avatar
What a neat project! I am tagging along
Sent from my SM-A520W using Tapatalk
Challenge Met
Have you met "The Fahn" yet?
https://www.mytractorforum.com/189-o...meet-fahn.html
MikMan48 is offline
post #5 of 11 Old 03-11-2019, 05:06 PM Thread Starter
Thanks. Its a standard HF Motorcycle lift table. I added the foldable wings and when the lift cylinder crapped out we added a air actuated HF jack and better casters.
ID:	2365989   Click image for larger version
ID:	2365991   Click image for larger version
ID:	2365993   Click image for larger version
post #6 of 11 Old 04-22-2019, 10:22 AM Thread Starter
Update from this weekend. Its pretty much done till we get the wheel spacers machined. Had to get creative to make the belt stop function so it would shift. The original belt cover did not match up to the engine so it wouldn't work. We cut it off and added a bolt with some rubber hose on top of the drive pulley and added a flat idler to help with the belt slapping the cover.
ID:	2373283   Click image for larger version
ID:	2373285   Click image for larger version
ID:	2373287   Click image for larger version
post #7 of 11 Old 04-22-2019, 10:42 AM
rudedawg's Avatar
Now that's way cool; slap some "moon eyes" on it and your'e set...lol.
rudedawg is offline
post #8 of 11 Old 04-23-2019, 12:07 AM
Hammerhead007's Avatar
I Like it. cool looking machine.
Hammerhead007 is online now
post #9 of 11 Old 04-23-2019, 02:15 AM
Collector of many tractors
Kbeitz's Avatar
I think I would move the gas tank...Doesn't make a good bumper...
Kbeitz is offline
post #10 of 11 Old 04-23-2019, 11:02 AM Thread Starter
Tank is fake.
post #11 of 11 Old 04-25-2019, 08:34 PM
DusterP94's Avatar
Probably the first tractor bumper I would call "exciting".
DusterP94 is offline
rat rods forkz Car Talk 0 09-15-2018 09:30 PM
Sears Mini Craftsman Rat Rod Project. suburban16 Craftsman/Sears Forum 29 02-03-2013 10:23 PM
Getting a little done on the 753...slowly rustyoldjunk Toro/Wheelhorse Forum 2 01-21-2013 09:03 PM
