Leaky Gas Tank On Echo Hedge Clipper - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 04-04-2019, 09:52 AM Thread Starter
hotajax's Avatar
I gots me a hedge clipper that's probably 25 years old. HCR-1500. It always has these mysterious drips coming from the bottom of the gas tank. I replaced fuel lines, the gas cap, and the plug that goes into the fuel tank. Yet the leaks remain. Do these plastic gas tanks go bad?
Other Question: If I buy a new tank, does it come with the bigger plug with the holes for the fuel lines to go through? Trying to thread the fuel lines through the smaller plug is a major PITA. Thanks in advance.
And even worse, I don't care.
hotajax is offline
post #2 of 10 Old 04-04-2019, 11:40 AM
Re: Leaky Gas Tank On Echo Hedge Clipper
Gas tanks do deteriorate with age. Good luck finding a new one for such an old machine. When replacing the fuel line cut the end at a sharp angle, feed it through the hole and grab the end with a small hook. Cut it square and fit the filter.
RoyM is offline
post #3 of 10 Old 04-04-2019, 11:44 AM
Also some lube on the line makes going thru that little hole a whole lot easier.
Junky is offline
post #4 of 10 Old 04-04-2019, 05:02 PM Thread Starter
hotajax's Avatar
I learned that on my wedding night.
hotajax is offline
post #5 of 10 Old 04-04-2019, 05:04 PM Thread Starter
hotajax's Avatar
Thanks, Roy. I had no idea that the particular type of plastic would deteriorate. Especially since it sits in the barn all the time.
hotajax is offline
post #6 of 10 Old 04-04-2019, 07:58 PM Thread Starter
hotajax's Avatar
hotajax is offline
post #7 of 10 Old 04-04-2019, 10:28 PM
LOL I bet you won't have a lot of trouble squeezing that little hose in there then!
I have a few old plastic tanks around as old or older and they do not leak, but the fuel lines and grommets do now and then. The pain is having the right sized hose on hand. I find that there's several possibilities.
Junky is offline
post #8 of 10 Old 04-04-2019, 11:27 PM
Minding my P's & Q's
JP Savage's Avatar
My hardware store carries 9 rolls of the different sized small fuel lines. Even then he can not match all of them he tells me.
Sent from my DELL WS650 Desktop PC, by tappity tap tap'n on the keyboard. And which not even once have I dropped down the hole in the outhouse.
Utility before aesthetics.
Craftsman GT Model: 917.251522, 46” Deck w/ CV20S Kohler, Built 1996, Hydro trany, lever control.
Craftsman, Model: 842.242560, 46” Snowblower attachment. Heavy and noisy.
Craftsman, Model: 917.249740, 3 bin, Hard side Bagger.
Murray LT Model: 425618x48B, 18hp B&S, 42" deck, 2004, Hydro trany., foot control. My Mower
Murray RER, Model 30550H, 1999, 10 hp Tecumseh, 30” cut, single blade. My trimmer.
Murray, Noma Model: 633124X8, 12hp Tecumseh OHSK120, 33", 1997, Walk behind snow blower.
MTD Snowblower Model: 317E150-129, 139cc / 21”, 1996 My “Power Shovel”.
JP Savage is online now
post #9 of 10 Old 04-15-2019, 05:27 AM
lawnboyben's Avatar
[QUOTE=hotajax;12237759]I gots me a hedge clipper that's probably 25 years old. HCR-1500. It always has these mysterious drips coming from the bottom of the gas tank. I replaced fuel lines, the gas cap, and the plug that goes into the fuel tank. Yet the leaks remain. Do these plastic gas tanks go bad?
Other Question: If I buy a new tank, does it come with the bigger plug with the holes for the fuel lines to go through? Trying to thread the fuel lines through the smaller plug is a major PITA. Thanks in advance.[/
I went through the same issue with my 20+ year old secondhand Echo backpack blower. For the life of me I couldn't find the source of the leak anywhere until I removed the tank filled it with soapy water and pressurized it. Where the bracket held it to the frame was worn thin and the vibrations eventually caused spiderweb cracks in the brittle old plastic. So in my experience they definitely go bad. My replacement tank didn't come with a new rubber grommet that the fuel line(s) go through but they should only be a few bucks from Echo. the new tank was worth it for me, and if your machine runs good I think it would be in your case as well.
Lawn-Boys
1991 C21ZPN
1994 10520
1995 10545
1999 22261
Blowers
Echo PB-400E
Husqvarna 125B
Trimmers
Husqvarna 128LD
Echo SRM-2400
Echo SRM-210
lawnboyben is offline
post #10 of 10 Old 04-15-2019, 06:04 AM
Blank Space
Corn squeezins damage all kinds of stuff.
Couple of kits I got had a small diameter wire about 8-10" long with a small hook bent in one end. Fish it into the tank through the filler neck and through the small hole, then into the hose/tube. Pull it back through the filler neck and it pulls the line through the hole. Helps to hold the line taught so it stretches a bit reducing the diameter. When it relaxes, it goes back to normal diameter and seals the hole
New LS MT125 Mods. Bucket Level Rod and Fuel Transfer. Singalo The Shed 7 03-06-2019 06:11 PM
Small Echo Hedge Clipper Runs Screwy. Help Please? hotajax Small Engines and Repair 1 01-30-2019 01:09 PM
Gas Into Muffler Echo Blower Brad Chippers, Trimmers, Leaf Blowers and Vacuums 4 01-28-2018 05:37 AM
GAS TANK RUBBER GROMMET-how to replace? put grommet in tank first or on tube first??? ericwest Craftsman/Sears Forum 2 01-29-2013 10:45 AM
Good uses for old Echo premix gas? mikeinri Small Engines and Repair 15 11-19-2012 09:59 PM
