Husqvarna 224L trimmer stalling - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 09-23-2018, 05:40 PM Thread Starter
Hey guys, my 224L has begun stalling. I tried replacing the spark plug to no avail.
One thing I noticed while replacing the spark plug was that the air filter was soaked with gas. I'm no mechanic, but this makes me think the carborator may be leaking?
Any thoughts or ideas would be much appreciated, thanks!
Hans Gruber is offline
post #2 of 4 Old 09-23-2018, 07:04 PM
Re: Husqvarna 224L trimmer stalling
I have a 223L that I found at the local dump. Tore into the carb and found the fuel inlet screen was plugged with gel. Cleaned it up and it runs great....on non-ethanol fuel.
Get a set of carb screwdrivers off of ebay so you can adjust the mixture screws and it should run like a champ again.
1997 345 54" deck, powerflo, 42" snowblower.
1996 LX173 48" deck, powerflo, sold snowblower.
1990 955, ser #007, 70 FEL, 72" MMM, 5' Ford brush hog
1951 Ford 8N w/Howard underdrive and Wagner FEL SOLD
svobronco is offline
post #3 of 4 Old 10-06-2018, 08:13 PM Thread Starter
Thanks for your reply!
Now that I've had a chance to tear into it, I figured out that the problem is a cracked fuel line. I'm noticing that there are two different fuel lines, a clear one and a black one. The black one is cracked. Any idea what size the lines are so I can replace? Or are they all the same?
post #4 of 4 Old 10-09-2018, 11:47 PM
M21BMR's Avatar
Black 5mm x 3mm (exterior diameter x interior diameter) fuel line will work on almost all string trimmer engines.
I have also used 3/32" interior diameter tygon (clear) line. Usually, the black line is the intake line and the clear line is the return line. The intake line will have the in-tank fuel filter attached.
2005 John Deere L111
1991 Lawn Boy M21BMR
John Deere E35 Edger
Echo CS-590 Chainsaw
Echo CS-400 Chainsaw
Echo SRM-230 Trimmer
Echo ES-250 Shred-N-Vac
Echo PB-251 Blower
Echo HC-165 Hedge Trimmer
Stihl MS-193T Chainsaw
Toro (Ryobi) powerhead w/ trimmer, brushcutter, edger, pole saw, cultivator, hedge trimmer
Honda F220 Tiller
Troy-Bilt 5000W Generator
Husky 26 Gallon Air Compressor
Campbell Hausfeld Pressure Washer
Craftsman Shredder / Vac
M21BMR is offline
