Speed Feed trimmer head - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 19 Old 08-14-2018, 03:44 PM Thread Starter
My OEM Stihl trimmer head, I知 guessing, is kaput. The pop on/off cover will no longer stay on after respooling the head. I just found out about the Speed Feed heads. Is this the way to go? Any recommendations? After a short search, I found this one: Stens 385-288 Speed Feed 450 Trimmer Head https://www.amazon.com/dp/B008G4GMOU..._o7YCBbWHD4PJ8
cutngeaux is offline
post #2 of 19 Old 08-14-2018, 08:29 PM
10,000 +posts!
glenn27's Avatar
Re: Speed Feed trimmer head
Bump up!!
To the OP--I can't help with ur question, but this will bring it back to top.
Stens does make some good replaceable parts that I have bought from time to time-
Good luck--
glenn
Jimmy Buffett
glenn27 is offline
post #3 of 19 Old 08-14-2018, 08:30 PM Thread Starter
Why, Thank you!
post #4 of 19 Old 08-14-2018, 09:04 PM
I installed an Oregon Speed Feed on my Echo after the original grenaded and I couldn't source replacement parts locally. I was very happy with it, easy to load and it worked flawlessly. I did have to cut a notch in the debris shield so I could see the arrow to line it up with the eyelet.
RoyM is offline
post #5 of 19 Old 08-15-2018, 03:54 AM Thread Starter
I知 wondering why mine didn稚 go back together? I ran out of line, took it apart, respooled the line, and the cover wouldn稚 stay back on.
post #6 of 19 Old 08-15-2018, 03:46 PM
Two of, a bit cheaper, mind you it doesn't come with the different bushings so if it's not a 10mm x 1.25 LH thread you're sol. This one did tho https://www.amazon.ca/gp/product/B07...?ie=UTF8&psc=1
Beats the stealer price of $50 for one..........Mike
Iseki TM 3160
Mike Milburn is offline
post #7 of 19 Old 08-15-2018, 04:37 PM
sld961's Avatar
I have this SpeedFeed head on my Stihl and it works good and is easy to fill. I'm happy with it.
sld961 is online now
post #8 of 19 Old 08-17-2018, 01:59 AM Thread Starter
Which one?
post #9 of 19 Old 08-17-2018, 02:05 AM Thread Starter
I guess I should add, I have a FS-80.
post #10 of 19 Old 08-17-2018, 10:27 AM Thread Starter
Has anyone just bought a replacement cover?
post #11 of 19 Old 08-17-2018, 12:56 PM
i've never. The way i look at it, by the time the cover is worn thru, the rest is probably getting close to worn out also. I've never physically broken any of mine as in cracked a piece or a lug off, mine wear out from the rocks and ground contact...........Mike
Iseki TM 3160
post #12 of 19 Old 08-17-2018, 05:59 PM Thread Starter
Do I go w/ the 375 or 450? Or a non speed feed head like the T-35?
My head is spinning almost as fast as a trimmer head, researching all of these head designs.
Also, I do most of my trimming on concrete. Which line size/type do I use?
https://rover.ebay.com/rover/0/0/0?m...2F371576629115
https://rover.ebay.com/rover/0/0/0?m...2F123265270521
Husqvarna 537388101 Universal T35 Tap Advance Straight Shaft String Trimmer Head Prewound With .095-Inch Line https://www.amazon.com/dp/B000AM2IK8..._qr1DBbD47A9H2
post #13 of 19 Old 08-17-2018, 08:13 PM Thread Starter
Or this? Echo 99944200907 Speed-Feed 400 Universal Trimmer Head https://www.amazon.com/dp/B00G5KL0QW..._Er2DBbRWQQEZD
I知 kind of leaning towards the Echo.
post #14 of 19 Old 08-18-2018, 02:22 AM
I’m kind of leaning towards the Echo.
That's the kit I installed on my fs94r. Very good setup and easy to follow directions. I wasn't impressed with the included pre installed echo trimmer line so I swapped it out. But other than that I've been sold on it. Zero issues as of yet.
https://www.mytractorforum.com/index...topics/1284001
subdivisionbigdog is offline
post #15 of 19 Old 08-18-2018, 07:45 PM
I bought a speed feed head for my echo trimmer. The instructions were a little confusing, but once someone showed me how to do it, it was amazing. Takes maybe 30 seconds to restring without taking anything apart. I can't see myself ever using anything else
heathiopian is offline
