MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - Valve Adjustment
post #9 of Old 10-03-2019, 08:05 PM Thread Starter
Gerrard
Gerrard's Avatar
Re: Valve Adjustment
Originally Posted by Alien5044 View Post
Forget "cams" etc. The only thing you need to determine is that the valve you are adjusting is closed.
Remove the spark plugs and rotate the engine until both valves on the cylinder you are working on, are closed.
Look into the cylinder with a light, if the piston is right there, rotate slightly to be sure it is at its all the way "up" and stop there. You can do those valves when both are closed when the piston is at the very top of the cylinder. Repeat on the other if this is a twin.
Recheck after some run time.
Take your time and be logical. You can do this.
Yea I get it but its a single cyl. T head and the main thing and why its seeming so complicated and I have so many questions is Im just now putting the whole tractor back together. 85% of it is still scattered everywhere.
Thanks Im goin out there right now and setting them. Just got home from work.
Gerrard is offline
