MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - Valve Adjustment
post #8 of Old 10-03-2019, 02:55 PM
Alien5044
Re: Valve Adjustment
Forget "cams" etc. The only thing you need to determine is that the valve you are adjusting is closed.
Remove the spark plugs and rotate the engine until both valves on the cylinder you are working on, are closed.
Look into the cylinder with a light, if the piston is right there, rotate slightly to be sure it is at its all the way "up" and stop there. You can do those valves when both are closed when the piston is at the very top of the cylinder. Repeat on the other if this is a twin.
Recheck after some run time.
Take your time and be logical. You can do this.
X 500 48" Deck 48" blade
Cyclone Rake
Stihl BR 600
Sears Suburban Super 12 1968
Alien5044 is offline
