MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - Valve Adjustment
post #3 of Old 10-02-2019, 08:16 PM
RI-GravelyMod
Re: Valve Adjustment
Gerrand,
In the shops where I worked on all make of engines we checked or set the valve clearance using this method:
When the exhaust valve is fully open you check or set the intake valve clearance.
When the intake valve is fully open you check or set the exhaust valve clearance.
Trouble with Gravely and other engines is the pounding action of the valve stems into the lifters causes wear on both parts. This wear can cause an error when you check or set your actual gap.
RB
RI-GravelyMod is offline
