MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - 4TNV98 RPM meter take off
post #6 of Old 09-16-2019, 04:33 PM
tomw0
Re: 4TNV98 RPM meter take off
https://www.yanmar.com/us/wp-content...ting_Guide.pdf
Seems to have an ECM that fiddles with the injectors, etc. Bet there's an output from that which is used to operate a tach.
Page 9, number 3, the 'speed sensor', optional...
Or the 'service manual' from here:
http://www.paul-forrer.ch/items/7025...ice_Manual.pdf
An electronic display would need to be wired, by individual wire conductors, to the engine to have information to display. Follow the wires back to the engine. Think on where the wires are attached, such as sitting by the crankshaft(crank position sensor), perhaps used to count revs?, or the cam position sensor, ditto. Other methods would be 'derived' numbers, such as counting injector pulses.(same as cam Hz., 1/2 crank)
tom
simplificate & add lightness
tomw0 is offline
