MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - Bent deck?
Thread: Bent deck?
post #8 of Old 08-25-2019, 03:13 PM Thread Starter
ccsial
ccsial's Avatar
Location: Northern IL 30 mi NW of Rockford, IL in farm country
Re: Bent deck?
I am going to try the shim route. I calculated that I need two .080 shims. I have some 5/16 washers that are .072. Close enough for gummint work.
Id like some advice about getting the belt pulley off. I figure to use an impact to get the nut off but will I need a puller after that? Any tricks you guys know about that? Does it have a keyed shaft?
Thanks, Al
JD X748SE - Kubota L3400HST - Ford 1910 4WD FEL
ccsial is offline
