MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - kubota b1550 hst want pull
post #2 of Old 08-17-2019, 02:41 AM
TUDOR
20,000 Posts & Climbing
Re: kubota b1550 hst want pull
Check the linkages to make sure that
1) the brake itself is not engaged, and
2) the shaft in the transmission controlled by the foot pedal actually turns.
There shouldn't be a problem with either, but something as simple as a connecting pin or key securing a bell crank to a shaft that has sheared or moved out of position can have the same effect and is easy to verify.
Are there any other symptoms, or performance level changes, that occurred prior to the loss of power?
TUDOR is online now
