MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - adding fuel gauge to 335
post #4 of Old 08-14-2019, 07:00 PM
Jimbochap
Jimbochap's Avatar
Re: adding fuel gauge to 335
Originally Posted by inspectorudy View Post
They are available for about $20. It is the type that replaces the fuel cap and has the gauge in the top. If you are thinking about an electrical gauge then you would have to find a tank that comes with a sending unit built for it. Most of JD's fuel tanks are a peculiar shape and a normal symmetrical unit will not give accurate readings. And then there is the issue of how to install it into a tank if you try to use your current tank. You will have to cut a hole in the top of your tank and install the sending unit and then make sure that it does not impact the seat/fender. If it were me for the meager benefit that an electric gauge would offer, I would buy the screw-on cap style and call it a day.
Clean the back of the tractor where you can see the level of fuel in the gas tank.
John Deere X495
54" Mower Deck
Front Hitch w/ 54" Snowblade
Buford Bucket
Click N'Go Bracket
Rear Weight Bar
6 Suit Case Weights
Cast Iron Rear Wheel Weights
JD 345 SOLD
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Jimbochap is online now
