MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - Found in the woods - Metal Tube with with screw on end
post #1 of Old 08-10-2019, 07:36 PM Thread Starter
Jere39
Have Dog - Will Travel
Jere39's Avatar
I found this small tube, about 6" long and 3/4" outside diameter. It is made of a metal that has not oxidized. It has a screw on top that has oxidized green like copper so perhaps brass. The top/lid has a dimple in the center as though it might center something inside. I cleaned it up and gave the top a good soak in WD-40, and I suppose I'll attempt to open it unless one of you recognize it as a canister of some component of a WMD. It's hardly big enough for anything I can think of that might have been used for a shooting sport.
Anyway, I'll let this here for a day or so before attempting to open it. If you don't hear from me again, you should suspect it was not safe.
Thanks for any hints
ID:	2390343   Click image for larger version
ID:	2390345   Click image for larger version
Jere39 is offline
