MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - Model L stops pulling when PTO is engaged
post #6 of Old 08-10-2019, 03:05 PM
franklin2
Re: Model L stops pulling when PTO is engaged
That happens to me when I forget and leave the hi-lo lever in neutral. If that is not the problem, try it first in hi, then in lo and see how it reacts. Make sure this hi-lo clutch is adjusted correctly with enough tension on the lever.
franklin2 is offline
