MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - Uphill in 2nd; 30 Minutes Later, Not So Much
post #31 of Old 05-01-2019, 02:52 AM
TUDOR
20,000 Posts & Climbing
Re: Uphill in 2nd; 30 Minutes Later, Not So Much
Originally Posted by Dee_Veloper View Post
That indicates to me an engine problem. It could be in the ignition, as my power problem was, or it could be in the governor (if it has one )/ fuel problem. You also may want to check the engine compression.
Engines produce torque, and over a specific amount of time, that torque translates into horsepower. If the load is too great, the engine rpm will drop and less torque and horsepower are produced. If the load stops, so does the engine, unless there is slippage somewhere in the drive train.
I have yet to see an internal combustion engine that slips under load. A reduction in engine rpm due to poor ignition, carburation, or timing is not the same as slippage.
TUDOR is offline
