MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - New to me material lift
post #7 of Old 03-26-2019, 06:09 PM Thread Starter
Dee_Veloper
Re: New to me material lift
Originally Posted by deereboy55 View Post
After you mount it on your tractor ,put a 12 volt winch in the place of the hand crank,with winch control near steering wheel.
Good thought. Might be a bit more complicated because I will still want to be able to use it off the tractor.
I may be able to use a battery powered drill because the hand crank is already designed to be removable by simply pulling out a spring loaded retainer pin.
Dee_Veloper is offline
