MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - Advice - Used Simplicity Conquest
post #2 of Old 02-21-2019, 01:45 PM
kb4212
Learning the hard way
kb4212's Avatar
Re: Advice - Used Simplicity Conquest
Welcome to the forum.
1) 18HP more than enough power for the 50". You could get 50"'s on them brand new.
2) Price it too high. It's definitely an older one say from the early 2000's. I think around 1000 a better price for average used condition. Safe to assume someone listing for 1595 is probably a re-seller so you might not get good history of the machine.
3) Make sure to run it awhile and get it hot and transmission hot too. Go up hills when it's hot. The deck lift handles like to wear out, make sure it operates like it should. Check for leaks around the crankshaft underneath. Check to make sure engine is not all packed with grass etc. under the shrouds as best you can.
2004 Simplicity Legacy XL 4x4 27HP Diesel with 48" deck, 60" 4-way snow/dirt plow, 46" 2-stage snow blower, 3-point, rear PTO, and FEL
1950 Ford 8n Sherman Step-up (in the family since new) and Dearborn 19-5 rear blade
https://www.youtube.com/user/W1WEASEL
kb4212 is offline
