MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - Need Gravely Info
post #2 of Old 01-18-2019, 02:20 PM
nhgravely
Re: Need Gravely Info
As far as I know, all true Gravely designed and built engines used the remote mounted magneto. Maybe one of more knowledgeable guys on here can confirm this.
Just saying, the WICO or F-M mags are not that hard to fix at home as long as the coil is good and the rotor has not lost it's charge. And the timing is easy, especially if you can get an accurate measurement on the piston location @ TDC.
nhgravely is offline
