MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - Onan B48M solenoid/starter
post #7 of Old 11-06-2018, 01:24 PM
ssmewing
Hemlock Case Guy
Re: Onan B48M solenoid/starter
Originally Posted by larrypac View Post
Is the ideal that I will check at the battery and not have any drop in that voltage all the way to the starter? Also if I short across the solenoid terminals and still have the problem, does that eliminate the ignition switch as the problem?
If you have battery voltage at the starter and jump the solenoid from there and have the same problem then it is the starter. That is assuming that you have good cables and connectors that can carry the amp draw. I have a drawer with a lot of undersized former battery cables.
I would research what type of lube is needed. I cannot recall what kind is used but I don't think it is just oil. You may be able to use the straw and get brake cleaner on it. Be careful about making holes in the tins, unless you are also going to patch them. That cooling air is needed very much.
ssmewing is offline
