MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - Onan B48M solenoid/starter
post #6 of Old 11-05-2018, 09:17 AM Thread Starter
larrypac
Re: Onan B48M solenoid/starter
Originally Posted by ssmewing View Post
You need to check the electrical health of the components. The reason is if you are dropping a volt or so along the way, it may be hard to notice, you may not be spinning the starter at full speed.
You start at the battery and end at the starter. Are both battery cables clean and do they both have quality battery terminal ends?
If you want to just replace an item that is the most common problem, replace the ignition switch which you can buy from a Case parts dealer. The switch is very odd and not found elsewhere.
Is the ideal that I will check at the battery and not have any drop in that voltage all the way to the starter? Also if I short across the solenoid terminals and still have the problem, does that eliminate the ignition switch as the problem?
larrypac is offline
