Z655 Sensitive Steering - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 05-20-2019, 08:20 AM Thread Starter
RT3360's Avatar
Looked at a Z655 with less than 200 hrs on it. Looks in great shape, but when I drove it the controls seemed a bit touchy which made it tough to mow straight. I know you should get used to it with use, but Im nervous after having driven a residential Husqvarna that was even more sensitive, a Kubota that didnt steer bad, and now this one. Everything else I own is tractors.
Is there a way to adjust the sensitivity of the controls to make it less responsive without losing top speed?
Craftsman DLT2000, 48
Ariens ST824 snowblower
RT3360 is offline
post #2 of 6 Old 05-20-2019, 10:06 AM
Re: Z655 Sensitive Steering
I have a Z655 I just bought with 105 hrs on it, it's my first zero turn mower so I don't have anything to compare to. I found if you don't put the throttle all the way to the fastest it will go it seems better to control., maybe you could try that.
9297oldram is offline
post #3 of 6 Old 05-20-2019, 11:34 AM Thread Starter
RT3360's Avatar
Interesting thought for general maneuvering, but for cutting Id want to be at full speed. I called the local dealer and was told there isnt any adjustment. Weird how much difference there is from machine to machine, maybe manufacturers.
RT3360 is offline
post #4 of 6 Old 05-20-2019, 11:43 AM
I cut with it at full speed and a little lower speed and it cut the grass the same. Only difference I noticed it wouldn't go as fast which was ok for me since my yard isn't real smooth.
post #5 of 6 Old 06-01-2019, 08:04 AM Thread Starter
RT3360's Avatar
Well, I finally decided to buy the Z655 and called the owner Thursday night. He said he had someone coming a long way to look at it. I asked him to call me back if the guy decided not to take it. Owner called back about 1/2 hr later and said it sold (under 200 hrs - $3650). He has a friend that services lawn equipment who told him theres a fair amount of variation in steering in ZTRs and the Z655 is more sensitive.
Off looking at other alternatives.
RT3360 is offline
post #6 of 6 Old 06-01-2019, 08:09 AM
That was a good price mine had 105 hrs on it and I paid $3900.
GT 3204 Power Steering gcarz102 Cub Cadet Forum 12 06-30-2018 04:12 AM
Do I need to rebuild my 318's steering valve?? lotsofspareparts John Deere Forum 7 11-15-2017 11:00 PM
317 Power Steering Conversion using 400 parts xtinctss John Deere Forum 17 08-21-2013 03:51 PM
Tractors, 90's - 2000 Vintage, Steering Problems Part #1 andyjw Backyard Round Table - L & G Tractor Related Topics 10 04-02-2013 04:35 PM
Ford 2600 power assist steering problems??!! blyberg1 Ford/New Holland Tractors 11 01-30-2013 07:34 PM
