Drive Chain Help Dixon ZTR 308 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 04-12-2019, 09:37 AM Thread Starter
Hi,
I have done a fairly decent search of the internet and all I can find are exploded diagrams that show parts, but no real information on what kind of chain the Dixon ZTR 308 (cone drive) uses.
I am not a chain expert so I can't tell what it is simply by looking at it. So I am looking to find out stuff like what are the chain specs, I want to replace the original drive chain (from the gearbox down to the wheel) with a longer chain, but have no clue what to order.
I am hoping there is someone on the forum who is a bit more chain savvy than myself, that can provide me with usable info that leads to a purchase of some generic chain.
Thanks in advance.
(yes I know the sprocket is not all that flash looking, but I am hoping it will see out my mowing requirements)
Bad Wolf is offline
post #2 of 10 Old 04-12-2019, 11:40 AM Thread Starter
Re: Drive Chain Help Dixon ZTR 308
I received the answer via PM (look for code on chain). Thank you for looking at my problem... Problem solved.
Edit:
The chain is 08B just in case anyone is chasing one down the track.
Bad Wolf is offline
post #3 of 10 Old 04-15-2019, 09:11 AM
Roller chain for the mowers is #40 if I recall. I buy boxes of it at the Farm store and cut it to length. The short internal chains can also use the same chain size. https://www.usarollerchain.com/rolle...art-s/4869.htm
1973 Case 646
1968 Case 155
1958 JI Case 310 Terratrac Crawler Loader
sddunt is offline
post #4 of 10 Old 04-15-2019, 11:55 PM Thread Starter
Without getting out a calculator to do the conversion they look similar... https://www.usarollerchain.com/08B-M...ller-chain.htm
Bad Wolf is offline
post #5 of 10 Old 04-16-2019, 02:37 AM
20,000 Posts & Climbing
Similar is not the same. Take the time to do the dimensional conversions. The #40 chain has a slightly shorter pitch which will cause problems.
TUDOR is offline
post #6 of 10 Old 04-16-2019, 04:26 AM Thread Starter
I guess the million dollar question is... Do I have the right chain on there now? The chain I have on there is an 08B is that the right chain or should it be a #40?
Bad Wolf is offline
post #7 of 10 Old 04-16-2019, 08:36 AM
Senior MTF Poster
We have run Dixon mowers for around 40 years and I have been a certified Dixon Service Tech. I run #40 chain which I buy at farm supply stores in 10 ft. rolls as said above.
Walt Conner
Walt 2002 is offline
post #8 of 10 Old 04-16-2019, 09:01 AM Thread Starter
Walt Conner
I thought it was strange that it would have a British standard chain on it... So I am guessing somewhere along the line someone switched out the right chain for an 08B. Lucky I found out before I bought sprockets for the motors. (which I am having trouble finding at a reasonable price). https://www.superdroidrobots.com/sho...7mm-bore/2276/
Bad Wolf is offline
post #9 of 10 Old 04-16-2019, 09:39 PM
Senior MTF Poster
What are you talking about, "sprockets for motors"? There are 9 tooth sprockets on the Discup Shafts. They are a little hard to find and expensive running from $15 ea. up depending on supplier. I have found cheaper ones which the description indicates they should work but haven't tried them yet as I still have a set of new OEM ones. There are roll pin and nut/key ones of these available so be sure you are getting the right ones.
Walt Conner
post #10 of 10 Old 04-17-2019, 01:46 AM Thread Starter
Walt Conner
One of these will be powering each wheel for drive. These are the sprockets I am talking about 17mm bore 6mm keyway being expensive. https://www.superdroidrobots.com/sho...7mm-bore/2276/
Crazy $85 USD each + postage which would probably be another $30-$50 USD
Bad Wolf is offline
Help with Snow Blower drive chain nylyon Toro/Wheelhorse Forum 9 11-26-2018 07:04 PM
WANTED: Murray 9-30502 chain drive rear end [email protected] For Sale & Wanted to Buy (Your Location) 0 06-26-2018 02:04 AM
ZTR hydros and chain link harrow robhay2 Mid Mount ZTR 4 05-01-2018 12:51 AM
Burns chain drive tiller Cannon51 Tiller Talk 5 02-06-2018 08:02 AM
model 49 snow blower correct chain drive tension oldyankeebarn1390 John Deere Forum 1 12-14-2017 09:44 PM
