Dixon zero turn? - Page 3 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #31 of 33 Old 05-06-2019, 10:13 PM
Collector of many tractors
Kbeitz's Avatar
Re: Dixon zero turn?
I have used the cone drives for years with no problems. They gotta be one of the most fun to drive zero-turns.
Kbeitz is offline
post #32 of 33 Old 05-06-2019, 10:32 PM
I find they drive about like any other zero-turn of the same size and length but they certainly do make some noise when they come drive starts to wear.
TobyU is offline
post #33 of 33 Old 05-11-2019, 10:02 AM
Senior MTF Poster
One nice thing about the cone drive is it takes hardly any hp to operate it as opposed to hydos which sap considerable hp just to operate them. When the cones start to chatter, growl, become noisy, it is a sign of uneven wear spots and will eventually cause cone to split, disintegrate. Might be able to "dress" them by gluing a 1" by 2-3" pc of 60 - 80 grit sand paper to 12" pc of 1/4" plywood and carefully smoothing surface while running being careful to not change contour of cone. I haven't tried that but have used that method to remove ridge around small end of cone.
You know they tried another "better idea" of making the cones steel and putting friction drive material lining inside the Discups. This was an expensive retro-fit and don't know how it worked out, only saw one of them. Not good enough obviously.
Walt Conner
Walt 2002 is online now
