Cub Cadet model 183649 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 19 Old 08-21-2017, 10:51 PM Thread Starter
Hope this is the right forum. I just acquired this machine. Seems to run great. A few issues, but easily dealt with. Where can I get either a user manual or shop manual for this? I have no idea of fluid types or volumes, or even blade numbers. So far I believe it needs new spindle bearings. I have to learn how to remove the 50" deck first. That's one of tomorrow's chores.
Thanks for any help and guidance.
mrcaptainbob is offline
post #2 of 19 Old 09-02-2017, 10:29 PM Thread Starter
Re: Cub Cadet model 183649
New blades are in, new spindles and deck reinforcement plates are on the way as are the four deck wheels. Lots of stress cracks were tended to today. I heard that high temp grease is required for zt units. True? I read about a unique deck wash system, too. And I found two fittings that look like quick connects. Air blasting shows they are through holes. Is there a unit that attaches to a garden hose to clip to these? Still trying to scare up an owners manual. So far it's an OtJT.
post #3 of 19 Old 09-27-2017, 02:16 PM Thread Starter
I did find a manual for this machine that also includes the deck info. Engine oil is freshened up, new spindles, reinforcements, blades and deck wheels. Are properly greased and lubed up. Runs great. There are two issues. The rear tires have different treads. The right is the typical Carlyle tread and seems to not have the best traction. Very easy to spin. I may swap them out next spring for better ones. That's where I need some suggestions. What kind of tread would work best for a ZT that's used on contoured ground?
The second issue is the tremendous amount of debris scattered from the deck. The spindle holes are so massive that there's a very, very large build up inside the end pulley covers. I see there are holes along the deck flange. Is there a debris guard for Cub ZT 50" deck? If not I was thinking of tire sidewall grade material attached to it to keep the tremendous amount of dust and grass clipping from spraying around. It has been a bit dry lately, there still are the weeds that like to poke up anyway. Yesterday was a challenge to see where I was going. Never had this issue before with any deck. Both, the machine and I were heavily covered. Air blasted most of it off before I got near the house. The blades are the kind with the notches in the wings. Could it be incorrect blade choice?
Thanks for any suggestions....
post #4 of 19 Old 10-01-2017, 06:02 AM
forkz
forkz's Avatar
mrcaptainbob i have a 06 z force 50 bought new been a greaqt machine 23 kohler command runs like new forget the deck wash out selling gimmick but standard quick connect fitting wally worlld probly got one used mine one time made more mess than good as long as i cut dry grass stays fairly clean top of deck another story front wheels trow grass on deck air gun leaf blower take care of that mine has good bearings in them keep them greased good
country in her soul but she loves to rock n roll charlie daniels
forkz is offline
post #5 of 19 Old 10-05-2017, 10:53 PM Thread Starter
Thanks, Forkz. Glad to know I'm not alone in this. I will be looking at installing some kind of shielding around the spindles at the deck. Just seems wrong to have the blades shoving that debris through those large deck holes. A winter time project...
post #6 of 19 Old 12-22-2017, 10:32 PM
Good luck with the Cadet ZTR Mrbob. Have had my 54" Cadet tractor with a 27 hp Kohler for 12 years now. Has done really great. My wife does persist to mow when it is too wet, so I try to clean deck. But, like the other guy said, it is probably best to just raise it up, and spray good with a hose and nozzle. I had a Wheel Horse that I neglected one time, and after several years, you could stick a knife through the rusty deck. Now, we have a ZTR. They both have their advantages, but we do like the speed and nimbleness of the ZTR. I am having an issue with one of the transaxles on the ZTR now. You do have 2 transmissions. On these residential models, there are no external oil filters, and they don't intend for us to change the fluid. Possibably, dirty fluid got mine in under 400 hours. I see where they recommend commercial units change their fluid every 250 hours or so. Looking back, I think I could have figured a way to at least changed the fluid - which might have helped it last longer. Hope you get along good with yours.
SlopeMan2 is offline
post #7 of 19 Old 05-25-2018, 11:40 PM Thread Starter
Geez, that sounds rough. 400 hurs is not a lot of time for that kind of issue! I'll be closely watching mine. Come to think of it, I'll be investigating on how to change out the hydro fluid tomorrow.
I do have another question. Now, this machine does a super great job with the new spindles, blades, etc. The PO had to have a new right rear tire installed, as the old one met a thorn in the sidewall. It's the standard Carlyle tread for a regular tractor type mower. It's traction is so-so on the straight and flat, but is pitiful at best in reverse. Also, ANY slope leaves this machine muddled. The mildest of slopes and neither rear tire wants t grab to do any kind of turn. Here's what I'm after: A new rear set of shoes for it. Something that will give better grip. I don't need knobby's, but maybe there's something midway? Any suggestions or experience is welcomed.
Thanks for any help....
post #8 of 19 Old 05-26-2018, 01:06 AM
Sorry about the debris problem on the deck Captainbob. Don't know what that could be. I have 3 mowers, and the only real problem is in the late fall, while trying to mulch leaves. I do have mulch blades, and I do have to blow leaves out from around the belts after each mowing. I do not use belt guards, so it is easy to do. But, they do not blow a lot of junk up to the operator.
You mentioned wheel spin. That is a problem with my Huskqvarna 54" with a solid front end. My Swisher ZTR has a pivoting front axle, and the rear wheels do not spin much. All have good tread. I saw on ebay, where someone has 20" mower tires for less than $20.
post #9 of 19 Old 05-27-2018, 03:26 PM Thread Starter
I guess the debris problem is something I will learn to live with. But I'm still looking for some better treaded rears.
I appreciate the help and suggestions....thank you all.
post #10 of 19 Old 05-28-2018, 12:37 AM
forkz
forkz's Avatar
captainbob mine has izt trans also sealed units i have ove a 1000 hrs on it still runs drives mows great
forkz is offline
post #11 of 19 Old 06-03-2018, 11:50 PM Thread Starter
Love how this machine sips fuel. I do have a question....how large is the fuel tank? Not mentioned in the book.
post #12 of 19 Old 06-04-2018, 12:11 AM
forkz
forkz's Avatar
not sure about yours captain mine holds 5 gallons yeah that kohler is very good on fuel
forkz is offline
post #13 of 19 Old 08-09-2019, 01:31 PM Thread Starter
Well, I'm lovin' this machine. The only thing better would be a 60" deck! But...it's all good. I think I found why the grass blows up through the spindle mounting holes. I used a set of those serious, high lift blades. Well, that upward pressure has to go somewhere and it all can't get past the chute fast enough. A of the debris was blowing from the deck top. A more normal blade set changed that.
I do have an issue, however. Those deck hanger straps. Nice cable wire with swaged (stupid!!) aluminum eye ends. Not going to replace them with the same anymore. I suspect solid link is not a good idea, so I'll be using some chain links with drilled steel eye plates instead. Anybody have issues like this? What was your solution?
post #14 of 19 Old 08-11-2019, 09:30 PM
forkz
forkz's Avatar
no problems with eyelets had to pull pan on one trans everything looked good but the oil changed the oil back like new i think it made it a little faster
forkz is offline
post #15 of 19 Old 08-15-2019, 10:45 PM Thread Starter
Just put a new air filter, plugs and fuel filter on it yesterday. Managed to remove the broken deck cables and replaced with two sets of chain, each three links. Not the correct length, but it will have to do for now. Maybe next week I can fab better stuff. Not a fan of something round rubbing crosswise on something round. Some of life's issues have gotten in the way for the past two weeks. Some sad stuff. Next week will hopefully be better. Did a test cut on the back area to see how things are. I like it for now. Will finish up the rest of the yards tomorrow.
Will look into that drive oil, Forkz. What kind of oil did you replace it with? How did you purge all the old stuff, and....how did you purge any air? Is there a drain plug for each drive?
