3 Point Help Needed - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 18 Old 03-16-2016, 03:54 PM Thread Starter
jdurnya's Avatar
3 Point Help Needed
Guys,
so i expressed some interest on the forum regarding "plow day" and im ready to start putting the pcs together.
So, seems like Ruegg is the way to go regarding 3 points. I spoke to Bill today as i heard mentioned that there is a cat 0 / cat 1 limited hitch available. And, it is infact orderable. ( even tho it isnt on his website )
What are your thoughts? is there an advantage to getting the cat 0 / cat 1 limited hitch ?
Tractors:
And then there were only 3...
1995 John Deere 425 AWS
1991 John Deere 420
1990 John Deere 430
Implements:
JD 40" Tow Behind Core Aerator
JD 40" Front Mount DeThatcher
JD 47 Snowblower
JD 54" Quick Hitch 4 way plow x2
JD Model 80 Cart
JD Tow Behind Sprayer
Custom front weight bracket / hitch receiver
Custom 4x5 to 300 series frame adapter
Custom Winch
Former Machines:
1996 John Deere LX176 my first Deere
jdurnya is offline
post #2 of 18 Old 03-16-2016, 04:08 PM
Re: 3 Point Help Needed
if it doesn't cost much vs cat0 only, then versatility is always nice
Rydplrs is offline
post #3 of 18 Old 03-16-2016, 05:41 PM
Mountain Man
mt.man511's Avatar
I just installed a Ruegg Cat 1 limited on my X475 loves this thing everything fit like a glove very heavy duty.
The Cat 1 limited has a wider variety of things you can hook on it.
The arms sit farther apart than the Cat 0.
Not sure what you are putting it on but if you can go cat 1 limited that's what i would do, you never know what you might want to do in the future and this will kind of future proof it for you.
mt.man511 is offline
post #4 of 18 Old 03-16-2016, 05:49 PM
TJR345's Avatar
If you can get cat one do so,it may only be cat 0 for the 425-455
Tom
2002 X595 with 62" deck front thatcher and Ruegg 3pt hitch
45 John Deere loader
Cat 1 3 pt plow and Heavy Hitch
62"powerflow
2019 X590 with 54" deck,power mulch kit and powerflow bagger
30" tiller,JD 18 cart
JD 40" spike aerator
12 suitcase weights
JD T105 trimmer
15 gal. tow sprayer
(2) JD JS63C walk-behind mowers
Turftime 60" roller
Turftime 54" 3pt core aerator
Frontier SS1036B Spreader
TJR345 is offline
post #5 of 18 Old 03-16-2016, 06:42 PM
surfed2death's Avatar
i went cat 0. some, if not most, implements were too big running cat 0 for my 316k. i used the cad plans on wfm and had the local welding shop build it. turned out great. here is a couple pics. first is when they were building it.
1978 John Deere 316
1980 John Deere 317 (Series 1)
1985 John Deere 116 Hydro-static
1992 John Deere LT150 5-Speed
surfed2death is offline
post #6 of 18 Old 03-16-2016, 06:51 PM Thread Starter
jdurnya's Avatar
Thanks for the input.. I am interested In a 10 or 12" plow. Would also like to maybe put a small box blade and a small sprayer. I think the capability of both would add versatility .
Please keep your input coming!
Tractors:
1991 John Deere 420
1990 John Deere 430
Implements:
JD 47 Snowblower
JD Model 80 Cart
Custom Winch
Former Machines:
jdurnya is offline
post #7 of 18 Old 03-16-2016, 06:52 PM Thread Starter
jdurnya's Avatar
Anyone running a 3 point aerator?
Tractors:
1991 John Deere 420
1990 John Deere 430
Implements:
JD 47 Snowblower
JD Model 80 Cart
Custom Winch
Former Machines:
jdurnya is offline
post #8 of 18 Old 03-16-2016, 07:55 PM
if you got a welder and some tools you can make your own plow. i built this one out of a horse drawn walk behind plow. a friend found it in a shelter belt on some property he bought and was going to scrap it so i got it for free. free is the best stuff. i just cut the front off of it to match the length i wanted and built a 3 point support. it works great. its 14" and a buggar to pull without weight and ag tires but the old 316k did it. it pulls alot better now with the ags filled with fluid.
1978 John Deere 316
post #9 of 18 Old 03-16-2016, 08:06 PM
martincom's Avatar
Are you installing on your 425 or other?
martincom is offline
post #10 of 18 Old 03-16-2016, 10:05 PM
Bill does make a cat o and 1 for the 425-455, You can call him or look on ebay, He sells both on ebay but usually he will knock a couple dollars off if you order direct from him.
stanley55 is offline
post #11 of 18 Old 03-16-2016, 10:51 PM
Jerry
MNvet's Avatar
I have a Ryan, weighs 515#. I have an X748.
John Deere X748 and assorted attachments
MNvet is offline
post #12 of 18 Old 03-16-2016, 11:36 PM
martincom's Avatar
If you're considering a Ruegg hitch for your 425, you may have issues if you also have a PTO and/or utilize CAT 1 attachments that connect directly to the rock shaft's link arm pin, without utilizing the adjustable upper link.
I've purchased two Ruegg CAT 1 3-points for 455s. The first was a number of years ago, Early CAT 1 Photo, and the second, Late CAT 1, was last fall. The first hitch has worked well all these years with no issues. The second hitch, however, immediately presented issues--before installation was complete.
The later hitch's left lift arm would hit the PTO selector level when in the full up position, not allowing it to be moved. It was putting enough force against the knob where it would only be a matter of time before it damaged the knob. It appeared to be an issue with the lift arm position on the rock shaft being too high. This was also evident as the lift arm would hit the frame when full up, acting as unintended up stop.
The other issue I had with the later hitch was that the rock shift upper link arms were sized and spaced for a CAT 0 pin and arm. The adjustable upper link had a CAT 0 eyelet on one end and a CAT 1 eyelet on the other end. This created an issue if an attachment did not utilize the upper link, such as a post hole auger. It wasn't just the smaller pin diameter, but the spacing between the rock shaft pin arms was also narrower than the CAT 1 eyelet. So even if you utilized a reducing bushing to get around the pin diameter, a CAT 1 eyelet was still too wide for the arm spacing.
Bill is a man of his word and his satisfaction guaranteed promise. He had an early version CAT 1 hitch for a 4X5 that had been returned, but not re-sold due to the paint being chipped up during shipping. He re-powder coated the early version hitch and sent it out to replace the later version. Bill took care of all the shipping charges.
If either of my issues could be an issue for you, you may want to check with Bill to determine if he has made revisions to correct these issues.
Hold mouse pointer over image for description:
Name:	Early CAT1 full down.JPG
ID:	1612850   Click image for larger version
Name:	Late CAT 1 full down.JPG
ID:	1612962   Click image for larger version
Name:	Arm Contacts PTO knob 2.JPG
ID:	1612970   Click image for larger version
Name:	Arm Contacts PTO Knob.JPG
Name:	CAT 0 Pin and Arm Spacing.JPG
ID:	1612986   Click image for larger version
Name:	Frame is up stop.JPG
ID:	1612994   Click image for larger version
Name:	Link Adjusted for full down.JPG
post #13 of 18 Old 03-16-2016, 11:44 PM Thread Starter
jdurnya's Avatar
Martincom Sorry for the late response, just got home. It's a 420 tractor I'm purchasing this for
Tractors:
1991 John Deere 420
1990 John Deere 430
Implements:
JD 47 Snowblower
JD Model 80 Cart
Custom Winch
Former Machines:
jdurnya is offline
post #14 of 18 Old 03-16-2016, 11:46 PM Thread Starter
jdurnya's Avatar
Nice... Does it work well? Improve your lawn?
Tractors:
1991 John Deere 420
1990 John Deere 430
Implements:
JD 47 Snowblower
JD Model 80 Cart
Custom Winch
Former Machines:
jdurnya is offline
post #15 of 18 Old 03-17-2016, 01:04 AM Thread Starter
jdurnya's Avatar
Keith,
your mailbox is full
Joe
Tractors:
1991 John Deere 420
1990 John Deere 430
Implements:
JD 47 Snowblower
JD Model 80 Cart
Custom Winch
Former Machines:
jdurnya is offline
