Ruegg 3 point hitch - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 18 Old 08-20-2015, 09:39 PM Thread Starter
biggreen455's Avatar
Ruegg 3 point hitch
Does anyone know if i can still use my MC519 Material collection system with a Ruegg 3 point hitch or will i have to take it off?
Thanks
BIGGREEN455
biggreen455 is offline
post #2 of 18 Old 08-21-2015, 01:57 AM
Love my X485
sdwalter's Avatar
Re: Ruegg 3 point hitch
Not sure how the MC519 connects to the tractor, but I can use my 3 bag collection system with the click n go brackets with my Ruegg 3 pt. Just have to remove the lower arms. Pull a couple of pins and you are done.
2004 X485, Rear PTO, Ruegg 3pt Hitch, Pat's Easy Change Hooks, 62C mower deck, 14 bushel power flow, 47 blower, Click and Go weight bracket, OTC Cab, CTC Loader, Piranha Tooth Bar, 48" rotary brush cutter, 6' landscape rake, Heavy Hitch 3pt weight bracket and hitch, CMP 3pt dethatcher, liquid loaded tires, 25 bushel Easy Vac pull behind yard vac, 7 suitcase weights, 50 lb wheel weights, Terra Grip chains
sdwalter is offline
post #3 of 18 Old 08-21-2015, 07:46 AM Thread Starter
Thanks for the reply, but after looking at the way it mounts, I don't thing it will work.
Has anyone made a to mount a MC519 to 3 pt hitch??
Thanks
Roger
BIGGREEN455
post #4 of 18 Old 08-21-2015, 09:19 AM
425Forever's Avatar
I had a Ruegg 3 point hitch on my 425. When I hooked up my MC519, I had an adapter plate that bolted to the hitch plate. When I hitched up the MC519 cart, I just removed the lower arms from the 3 point hitch and everything worked fine.
My new x729 seems to be similar. The hitch adapter for the MC519 won't clear the lower arms of the Cat 1 JD hitch. So, I'll have to remove them too. In both cases, the arms detach easily so it shouldn't be an issue. This fall will be the first for my x729, so I hope I don't run into any surprises when I hook up my MC519 for the first time.
2012 x729 - 48" & 62" decks, 3pt hitch, front fenders, air ride seat.
60D 7-Iron deck (yes, it can work on an AWS tractor)
1992 JD 425 AWS - Gone but not forgotten
42" Hydraulic Tiller
MC519 cart and Powerflow
54" blade and quick hitch
Dump scoop
'65 model 80 cart with narrow wheels
Several old Wheel Horses
425Forever is offline
post #5 of 18 Old 08-21-2015, 09:20 AM
VALurker's Avatar
Thanks
Roger
I have been going over the various grass/leaf pickup options and found that Cyclone Rake offers an adapter for their machines that allow them to be mounted to the 3PH. Perhaps it could be modified to work with the MC519?
Paul
VALurker is online now
post #6 of 18 Old 08-21-2015, 01:50 PM Thread Starter
Thanks for the info.
Roger
BIGGREEN455
post #7 of 18 Old 08-21-2015, 05:39 PM
Kansas John Deere's Avatar
I hook my cart up to the 3 pt hitch. With the deck down where I cut the cart is level plus there is no way it will come loose from the tractor like it will do sometimes with the original set up................KJD
Kansas John Deere is offline
post #8 of 18 Old 08-24-2015, 04:49 PM Thread Starter
Well i ordered the Cat 1 3 point hitch from Bill Ruegg today. Should be in before next week. I will keep you posted on what i come up with for mounting my MC519 cart.
Also will have to sell my Click N Go Weight Box and order some other goodies, Like maybe a Heavy Hitch and some suit case weights.
BIGGREEN455
post #9 of 18 Old 11-07-2015, 04:37 PM Thread Starter
Well i finally got around to posting back on this thread.
Here are some pics of the 3 point hitch. This works awesome.
I had 60 yards of loam dropped after i raked all the roots and roots out. This area had some big pine trees with tons of roots. It took some time but the end result was nice
ID:	1475722   Click image for larger version
ID:	1475730   Click image for larger version
ID:	1475738   Click image for larger version
BIGGREEN455
post #10 of 18 Old 11-08-2015, 12:09 AM
Bills got a great product. I told him what I was doing, and he built me a hitch for my sears suburban. Granted I used a modified original hitch plate and did mods before calling. It fits and works like OEM.. He also shipped it before he secured payment, which is something few people do.
matt167 is offline
post #11 of 18 Old 11-08-2015, 08:43 AM
aquist06's Avatar
The Ruegg hitches are great! Your yard looks really nice, its always amazing what you can accomplish with these tractors.
Adam
aquist06 is offline
post #12 of 18 Old 11-08-2015, 03:28 PM
TJR345's Avatar
I like the Ruegg hitch because it has less bends in the lower arms then the deere.
Tom
2002 X595 with 62" deck front thatcher and Ruegg 3pt hitch
45 John Deere loader
Cat 1 3 pt plow and Heavy Hitch
62"powerflow
2019 X590 with 54" deck,power mulch kit and powerflow bagger
30" tiller,JD 18 cart
JD 40" spike aerator
12 suitcase weights
JD T105 trimmer
15 gal. tow sprayer
(2) JD JS63C walk-behind mowers
Turftime 60" roller
Turftime 54" 3pt core aerator
Frontier SS1036B Spreader
TJR345 is offline
post #13 of 18 Old 09-01-2016, 11:13 PM
So how did you end up hooking up the MC519 to the 3 pt hitch? I have the same issue to consider if/when I get a 3 pt.
Rob
2016 x758 w/60" HC mower, 54" snowblower, MC519 bagger
2010 2520 w/61" H130 loader, TA 42" forks, KK 60" Pro tiller, iMatch quick hitch, KK middle buster
1996 345 - Traded
Other toys: Stihl BR600 backpack blower; McCulloch chainsaws: 10-10S, 700, 805, 10-10; JD trimmer
2520:_______________________x758:______________________Faithful 345:________________
BigBlue is online now
post #14 of 18 Old 10-12-2016, 03:46 PM Thread Starter
Sorry for the late reply, been very busy.
I found that if i just remove lower arms on my 3 pt hitch and install the pins for the arms back in the holes, my cart fits on those pins. I did find they are a little sloppy, so i will be adding a bushing to fit over the pins with the correct out side dimensions to snug it up a bit.
BG455
BIGGREEN455
post #15 of 18 Old 10-12-2016, 08:33 PM
You were able to sort the pine roots out using only the York rake? You really did a supper job getting that all level.
SEVA318 is offline
You may post new threads
You may post replies
