x749 restoration......some assembly required - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 196 Old 07-26-2015, 11:01 AM Thread Starter
badgerland01's Avatar
I just purchased a well used x749 yesterday. It had a small electrical fire in the engine compartment and fried the wiring, hood assembly, and radiator. It has been "temporarily" wired to prove the tractor runs, drives, and mows. Is there a wiring diagram for this engine and tractor? I would like to give a shot at repairing the harness rather than replace it for $450. I am also looking for a new hood+headlight+grill assembly. If anybody has one for sale or knows about one, I am interested.
-I know....I know.
ID:	1368441   Click image for larger version
ID:	1368449   Click image for larger version
X749 "H-3 EDITION"
GX345
badgerland01 is offline
post #2 of 196 Old 07-26-2015, 11:11 AM
Proud JD Owner
Mach-1's Avatar
Re: x749 restoration......some assembly required
Wow. If this beast is worth putting back together, do yourself a favor and get a technical manual for starters. It has all the wiring diagrams in it. Second, for the time, hassle, and potential errors, trying to patch a burned up harness is not worth the trouble. Get one from JD along with the headlight wiring harness.
X749's are out of print and somewhat sought after. If you got it cheap enough, it's worth sticking a few bucks into it and fixing it right......You'll still come out ahead. How many hours are on her?
___________________________________
2008 X720 Ultimate
54" Blade
47" Snowblower
Powerflo Bagger
Mulch Kit
#18 Dump Cart
Mach-1 is offline
post #3 of 196 Old 07-26-2015, 11:26 AM Thread Starter
I was told it has 1200 hours, but won't know for sure until I get power to the dash.
X749 "H-3 EDITION"
GX345
post #4 of 196 Old 07-26-2015, 12:59 PM
RBRONKEMA GHTFD's Avatar
If you dont mind me asking what did you get it for? For roughly a grand you can have a nice running tractor. I would buy a wiring harness from deere and pick up a hood on ebay and re decal it if its not already for a 749.
07 John Deere X748
54c Deck
Cat. 1 Limited 3pt. hitch
540 Rear PTO
03 John Deere X585
54c Deck w/14 bushel bagger
45 Loader
47 Snowblower
51 Rotary Broom
54 Push Box
Curtis Cab
John Deere 10p Cart
Land Pride CAO556 Aerator
Sold
John Deere x475
48c deck
47 quick hitch blower
02 John Deere x585 rescue project.
RBRONKEMA GHTFD is offline
post #5 of 196 Old 07-26-2015, 02:01 PM
Is this one able to take a FEL?
Do you have the rear 540 pto and 3-point hitch?
That's an awesome machine, I hope you get it rebuilt well.
JD X530, new on 5/29/14. Great machine.
JD 2210, 54" deck, front loader, 48" tiller, 48" bush hog, York rake, 750 hrs
Snapper 21" walk behind, 2000 year model, 2nd engine
Stihl trimmer, edger, hedge clipper, blower
Husqvarna 18" chain saw
JRusche is offline
post #6 of 196 Old 07-26-2015, 02:39 PM Thread Starter
-I don't mind you asking, but before I tell you what I paid......what do you guys think it is worth?
-I have been looking on ebay with no luck. I will have to patient with that search.
X749 "H-3 EDITION"
GX345
post #7 of 196 Old 07-26-2015, 02:44 PM Thread Starter
It can take a FEL with slight sub-frame modifications the way I understand it. I may try my buford loader on it to see if I like it. I don't have, or need, a rear pto. I do have a 3 point that will fit it. It also already has the shafts thru the front axle to drive a snowblower or sweeper. I just need the long shaft to connect the mid-pto to the front pto. So that seems like a nice extra.
X749 "H-3 EDITION"
GX345
post #8 of 196 Old 07-26-2015, 02:51 PM
mrbeef's Avatar
Looks like a nice project. X749's are all across the board in price....... so it is tough to say...
Hopefully the instrument cluster is in working condition and you can find out the hours.
Tractors:
Former Machines:
Kohler Light Plant
mrbeef is offline
post #9 of 196 Old 07-26-2015, 03:03 PM Thread Starter
The cluster "looks" ok. Once I look over the wiring diagram, I should be able to temp a hot and ground wire to see if it works. It would be nice to keep the original hour meter.
X749 "H-3 EDITION"
GX345
post #10 of 196 Old 07-26-2015, 04:21 PM
burned300's Avatar
Your my hero taking on that project, I'm sure it will be worth it to make it pretty again!
1970 112
1975 200
Gannon Earthgavator graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
John Deere cat 1 plow
Innovative brand, Grapple
burned300 is online now
post #11 of 196 Old 07-26-2015, 04:37 PM
lightsOUT's Avatar
What a cool little project! I would love to find something like that.
If it were me, I would just replace the wiring harness with a new one from JD. I'm assuming you probably got a good deal so that's why I suggest going with a new harness. Save yourself some headache. However there is manuals available and it's not an overly complicated system should you decide to tackle it.
Good luck!
Robert
2007 x748
2012 Dodge Cummins
lightsOUT is offline
post #12 of 196 Old 07-26-2015, 04:50 PM Thread Starter
It looks like 80% of the harness is ok. It just needs everything around the engine replaced. It will be a couple months before I start the repairs. It will be used as a loader tractor for now. At least I don't have to worry about scratching it. Haha
X749 "H-3 EDITION"
GX345
post #13 of 196 Old 07-26-2015, 04:55 PM
There is a X595 harness on ebay for $200. that might be the same part of close enough to work. I have seen a X7 on before and it was under $150.
66 110 Sold
80 Struck Dozer Sold
77 Case 1816 Skidsteer awaiting time and parts
LX176 prepping for sale
LX277 AWS primary mower
214 project for sale
318 project for sale
455 project for sale
clarkwgriswold is offline
post #14 of 196 Old 07-26-2015, 06:02 PM Thread Starter
Thank you very much for looking. I saw that one the other day. It is an AM132603 and this x749 needs an AM136618. I haven't studied them side by side, but there must be several differences due to the $140 price difference from deere. Again, thanks for keeping an eye out. If anyone has first hand knowledge on whether or not the x595 harness would work, I would love to hear it.
X749 "H-3 EDITION"
GX345
post #15 of 196 Old 07-26-2015, 07:09 PM
GX345
jshillin's Avatar
It's hard to guess how much, $500 ? So, how much did you pay?
jshillin is offline
