JD 445 hydraulic lift - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 17 Old 06-28-2014, 08:46 PM Thread Starter
The mower deck won't raise on my 445. I pull the Top handle back and it whines, but the deck doesn't move. What might be the problem?
Thanks!!
pjwoodworker is offline
post #2 of 17 Old 06-28-2014, 10:37 PM
jpa2002's Avatar
Re: JD 445 hydraulic lift
Hydraulic lockout valve
Sent from the MTF Free App
2012 John Deere X748SE, 60D 7 iron deck, mulch kit, front quick hitch, 54" front blade (hardened shoes, rubber squeegee), SE seat, SE fenders, brushguard, rear receiver hitch, SE wheels, 3 pt hitch, rear PTO, striping kit.
jpa2002 is offline
post #3 of 17 Old 06-28-2014, 10:56 PM
TJR345's Avatar
Low oil.
Tom
2002 X595 with 62" deck front thatcher and Ruegg 3pt hitch
45 John Deere loader
Cat 1 3 pt plow and Heavy Hitch
62"powerflow
2019 X590 with 54" deck,power mulch kit and powerflow bagger
30" tiller,JD 18 cart
JD 40" spike aerator
12 suitcase weights
JD T105 trimmer
15 gal. tow sprayer
(2) JD JS63C walk-behind mowers
Turftime 60" roller
Turftime 54" 3pt core aerator
Frontier SS1036B Spreader
TJR345 is offline
post #4 of 17 Old 06-29-2014, 12:52 AM
20,000 Posts & Climbing
A low fluid level will also have a negative effect on hydro function.
TUDOR is offline
post #5 of 17 Old 06-29-2014, 10:08 AM
Another suggestion--change the transmission filter and oil. Over time moisture accumulates in the oil, from condensation. Oil also oxidizes, clogs the filter and becomes sticky. This contamination can affect a small hydraulic system, making the controls and pressure relief valves hang up. If the relief valve does not close properly, low pressure results, one possible cause of your problem. The o-rings and other parts do not get properly lubricated, accelerating wear. It is much cheaper to maintain than to replace or repair.
retsparky is offline
post #6 of 17 Old 07-01-2014, 12:08 PM
445MN
445MN's Avatar
Any luck on this, or does the problem still exist ? Inquiring minds (mine) want to know.
David
1996 445 w/345 hrs w/54" Deck and enhanced reverse pedal
2 bag Powerflo
54" front mount dethatcher
47" Two Stage Snowblower
1969? 80 cart restored
Sold: 1975 300 w/38" Deck
#49 Single Stage Snowthrower
#33 tiller
and 54" 4-Way Blade
445MN is offline
post #7 of 17 Old 07-04-2014, 08:19 PM Thread Starter
Been busy with other "must do" projects. Did get around to checking the oil level. it is fine. Although i discovered the seat will not slide forward to make easy access to the dip stick. The seat seems to be locked in place; even when moving the release handle.
Back to the hydraulic problem. Should I look next at the lockout valve? If so, where is it and how do i go about fixing it? Keep i mind that I am very mechanically challenged.
post #8 of 17 Old 07-14-2014, 02:31 PM
445MN
445MN's Avatar
Any updates, or did you give up for now ? I hope you get it resolved soon if you haven't already.
David
2 bag Powerflo
#33 tiller
and 54" 4-Way Blade
445MN is offline
post #9 of 17 Old 07-14-2014, 06:43 PM
sld961's Avatar
The lockout valve is down where the front hydraulic hookups are. It should be a t-handle valve. It should be open/close just like a regular valve. Did the deck operate properly before?
sld961 is online now
post #10 of 17 Old 07-14-2014, 08:41 PM Thread Starter
the problem is not yet resolved. I finally looked for the lockout valve tonight. Looked around the four hydraulic connectors under the left foot rest. No T-handle valve in sight. A picture or diagram might help.
post #11 of 17 Old 07-14-2014, 08:47 PM
Should look like this.
JD 455 3 pt rear pto 60 deck
JD 445 54 deck
JD 316, 46 deck
JD 425 parts tractor
Cockshutt 1465 parts tractor
pipsqueek is online now
post #12 of 17 Old 07-14-2014, 08:59 PM
445MN
445MN's Avatar
Hopefully this shows up, but this is the lockout valve.
2 bag Powerflo
#33 tiller
and 54" 4-Way Blade
445MN is offline
post #13 of 17 Old 07-15-2014, 08:39 PM Thread Starter
The pictures helped. They confirmed I was looking in the right place. There is no valve there. Only an elbow in the pipe. Now what should i do to try to fix the problem?
post #14 of 17 Old 07-15-2014, 08:57 PM
445MN
445MN's Avatar
You could pick up a valve on EBay.
2 bag Powerflo
#33 tiller
and 54" 4-Way Blade
445MN is offline
post #15 of 17 Old 07-15-2014, 09:51 PM
69project's Avatar
Keep working the lever back and forth. They sometimes stick on this tractor if they have not been used before. If this is a recent problem then:
1. Have you had the deck off/on recently and was it hooked back up correctly?
2. Where was the deck height set at? If you had it pretty high the deck won't move that much.
69project is offline
