317 resurrection - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 325 Old 03-29-2014, 10:46 PM Thread Starter
Alberta 7.3's Avatar
317 resurrection
I decided to bring one of my dead 317s back to life. Cabin fever this winter has been brutal, I needed something to do.
I will warn you now: this won't be a restore (nor should it be.)
The 317 had a unfortunate history as the red-headed step-child of the JD family, due to the KT17 issues. These non-running 317s usually can be picked up cheap (as mine was) and repowered and modified into a versatile little machine, usually for less than a good used running tractor.
The plan:
Diesel repower
H3 hydraulics
Power steering
minor bodywork/repaint
Dragged the 317 from it's icy tomb of the back 40. The seat was removed in the fall to prevent damage and stored indoors.
Rolling it into the shop was a chore, the freewheeling valve doesn't seem to be working, so the tires skidded their way in.
The white tag on the hood gives an ominous warning "CHECK OIL EVERY HOUR!!"
I am guessing this engine is a KT17 with some serious blow-by issues, since the oil fill tube has been replaced with a threaded pipe nipple and plug to keep the cap from being launched into oblivion. There are some pipe wrench marks on the driveshaft adapter, where someone rolled the engine over to break free a seized connecting rod bearing.
There may be a driveshaft issue.
After a few hours, I had a rolling frame.
For the repower, a JD 2653A golf course mower will be the unsuspecting organ donor. Reel mower units seem to sell for very cheap in my area, which makes them a good parts source.
The 2653A's harvested heart:
Set the new engine on the frame to get an idea of what needs to be done. I will need to modify the hydro linkage, and trim away the center pedestal support for engine and radiator clearance.
The 2653A was equipped with power steering, so the power steering unit and bracket were raided from the machine. Unfortunately, the steering unit has a very short column section (approx 6") which would have had the steering unit tight to the underside of the dash. The column tube and shaft were cut from the manual steering gear that was removed, then grafted to the power unit.
The donor bracket was cut and welded as required to fit the new custom column.
While I was cleaning the frame, I discovered what was causing the freewheeling valve issue. There was so much dirt packed around the freewheeling valves that the plate that depresses the valves was stopped by the compacted dirt.
Next, I had to modify the hydro linkage, so it would be tucked inside the frame rail area to clear the engine. The 2" angle now supports the pedestal center structure, as well as a base for the radiator to sit on.
A section of the frame crossmember had to be removed to accommodate the oil pan.
The crankshaft flange needs a 1" keyed shaft to connect to the driveshaft.
Luckily, it already had a 1" hole bored through the center. I broached a keyway and set it on the shaft.
To make sure the shaft and flange are true, I set up a couple pillow blocks on a bench, with a dial indicator to measure lateral runout.
A couple tack welds were placed, then the flange was tapped to get it straight. I felt it was close enough when I had the runout down to 0.003" at which point I welded it solid. After welding, the shaft was cut off at about 2". Final length will be determined once the driveshaft is being set up.
I had a friend at a fabrication shop cut me a 10" circle on the plasma table, which will be the start point of the bellhousing to support the PTO clutch.
I welded 2"x1/8" flat bar to the plate to create the bellhousing sides.
I cut the mounting tabs from the original flywheel guard that came with the engine and welded them to the new bellhousing.
Engine in place, there will be enough space above the PTO clutch to have the battery tray. Engine mounts are next item to address.
Bill
1968 JD 112D-H3, 46" model 47 deck, modified Troy-bilt chipper --> Build thread
1982 JD 317 H3, Hydro Steering, 3TNE68A Yanmar/JD diesel powah 317 resurrection
1982 JD 317 Kohler Series II
300 series attachments: 49 blower, 33 tiller, 48 mower, 54 4 way blade.
2004 Cub 5234D Loader, snowthrower, 60" deck The 5234D Rebuild
Snowblower Hydraulic Chute Control DIY
Alberta 7.3 is offline
post #2 of 325 Old 03-29-2014, 11:03 PM
mrbeef's Avatar
Re: 317 resurrection
I am subscribed. Looks great so far!!!
Tractors:
Former Machines:
Kohler Light Plant
mrbeef is offline
post #3 of 325 Old 03-29-2014, 11:12 PM
pctdavis's Avatar
On board as well. I love seeing what you guys with all the right tools in the shop can create.
Sent from my DROID RAZR HD using Tapatalk
Red meat is not bad for you. Green FUZZY meat is bad for you!
pctdavis is offline
post #4 of 325 Old 03-29-2014, 11:16 PM
Wow, that's the way to repower in a big way - she's gonna be torque monster. Might want to consider a locking rear diff to get power to the ground.
dirtintheeye is offline
post #5 of 325 Old 03-29-2014, 11:54 PM
not quins. but sextuplets
Whirly's Avatar
count me in as a peeker...
Whirly is offline
post #6 of 325 Old 03-30-2014, 12:03 AM
the mad scientist
Diesel!! I like this, thats going to be awesome keep up the good work
deereguy00 is offline
post #7 of 325 Old 03-30-2014, 12:29 AM
jar19800's Avatar
me too am lookie lookie! good luck and hope it works well
although, i did see the mouse motor in the background of one of the pics. now THAT would be cool
a few of my prized possessions
Craftsman GT6000: 26HP HG730 hydro. 54" mower, bagger, blade, sleeve hitch, plow, cultivator, disks, back blade, cart.
1986 John Deere 318: currently in pieces. Mower, 3pt, front and rear weight racks, Sleeve Hitch adapter, 54" 4way blade.
1981 John Deere 216: Tiller, blower, hitch and helper
1977 John Deere 400: 60" mower,home made dozer blade, 3pt carryall, and spare set of loaded Ag's yea i went there
1964 John Deere 110: Mower, Hitch, helper spring, narrow wheels original tires
2015 1025R with D180 loader I match and whatnot plus powerFlow D.O.D.
Cheers
jar19800 is offline
post #8 of 325 Old 03-30-2014, 12:31 AM
QAFarm's Avatar
Ah ha! Finally the thread I could get glimpses of and was waiting for.. Nice work so far. Did the flange move when you welded it?
1981 john Deere 317. 1986 John Deere 318
1964 International B414 1982 John Deere 400
10 s cart
26T John Deere sweeper
Model 50 cart
1969 Patio model 80 cart
1982 John Deere 80 cart
1976 John Deere 80 cart
Former equipment. 1979 JD 216 so others can live.
1999 Scott's 46 inch cut
1972 simplicity 3415H w/tiller
1977 JD 214
69 John Deere 112H SF
QAFarm is offline
post #9 of 325 Old 03-30-2014, 06:44 AM
Rebuilding my First JD GT
N2 Tractors's Avatar
Been waiting for this one. Power steering check, diesel re-power check, old 317 chassis tuff as nails... priceless. I'll be over here on the sidelines rooting for this little guy.
Running:
‘73 140 H1, ‘75 214, ‘79 JD 317 Onan P218G, 19xx Wheel Horse D250 550 Arc FEL ARPS Box blade
Not Running:
‘69 JD 140 H3, ‘75 JD 300, ‘79 JD 317 Kohler KT17QS II, ‘83 JD 420, late ‘80’s JD 316, ‘90 JD 316,
2x 300 series 3PH, Johnson Workhorse 12, Gannon Earthcavator 32”, 2x JD 54” 4way blade, 2x JD 33 Tiller + 8" Extension, JD 38” Brass tag mower deck, JD 48” mower deck, JD #30 Hydro Tiller, Disks, Plow, ARPS Angling Backblade,
N2 Tractors is offline
post #10 of 325 Old 03-30-2014, 09:06 AM
Schwinn68's Avatar
Very cool repower. I'll be watching this one too
1995 Deere 425 54" deck and 54" blade
26" tru powers and 18" v61
Deere 330 diesel 50" deck 54" blade----sold
Schwinn68 is offline
post #11 of 325 Old 03-30-2014, 10:48 AM
Diesels are awesome!
Diesel332's Avatar
Can't wait to see the final beast!
Mark
1967 110 RF, 1968 112, 1970 112 Patio Spruce Blue, 1973 70, 1973 110 electric lift, 1986 214, 1987 332 Diesel, and 1989 430 Diesel
Diesel332 is offline
post #12 of 325 Old 03-30-2014, 12:31 PM
Still lovin' the 322!
PA318Guy's Avatar
Yep I subscribed to this thread. This is really an interesting build! Great to have welding talent and equipment!
Current Machine JD 322
PA318Guy is offline
post #13 of 325 Old 03-30-2014, 01:51 PM
k91
Great work so far
1967 John Deere 110H
19? John Deere 332
k91 is offline
post #14 of 325 Old 03-30-2014, 02:02 PM
This looks like it's going to be good. I'm subscribing
amf232 is offline
post #15 of 325 Old 03-30-2014, 02:39 PM
Michael
snowplowdog1288's Avatar
Very cool...that's way more involved than I would be comfortable with but I would love to be able to do stuff like that.
Sent from the MTF Free App
That's a horrible idea! What time?
John Deere 317, integral hitch, 33 tiller, blower, and cab
John Deere 312, 46" deck, powerflow bagger
Jacobsen GT14 with Johnson Workhorse 10TC loader
snowplowdog1288 is offline
