62C Deck Rebuild - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 119 Old 01-04-2014, 07:40 PM Thread Starter
62C Deck Rebuild
I have a 62 deck that came with my "new" 2005 X585. Unfortunately it appears to have seen some weather and little maintenance, so I am going to rebuild it before spring arrives.
Looking at the JD parts page, it looks like they upgraded some things on the deck starting in 2012, SN 300,000. This includes a different belt, V grooved sheaves replace the flat idler and tensioner pulleys, and a different tensioner spring and mount (bushing) are used.
Looking at my deck, there is evidence of the belt slapping around, a well as wear on the belt from the original flat pulleys. My idlers are pretty much beat and need replacing so I am going to update the drive train on this deck to the latest configuration.
The last picture shows a mockup with the new belt, spring, and sheaves. The new spring is shorter and heavier, but would not fit over the new bushing that I received. The old spring does fit. For now I am using the old spring bracket. I might try turning a groove in the busing so I can use it.
I have seen the old and new belts listed with the same lengths, but the new one appears to be about 1" shorter, measured around the outside. The gap between the tensioner and the bumper also decreased from 2-1/4" to 1-1/4" with the new belt and sheaves. I am not sure if this difference is due to stretching of the old belt.
If someone has a picture of the newer tensioner configuration it would be interesting to see how Deere sets it up.
ID:	625986   Click image for larger version
ID:	625994   Click image for larger version
tractorPete is offline
post #2 of 119 Old 01-05-2014, 08:36 AM
TJR345's Avatar
Re: 62C Deck Rebuild
There wasn't any instructions for the upgrade.The dealer should or could tell you how and what they do to bring it up to the new specs.
Tom
2002 X595 with 62" deck front thatcher and Ruegg 3pt hitch
45 John Deere loader
Cat 1 3 pt plow and Heavy Hitch
62"powerflow
2019 X590 with 54" deck,power mulch kit and powerflow bagger
30" tiller,JD 18 cart
JD 40" spike aerator
12 suitcase weights
JD T105 trimmer
15 gal. tow sprayer
(2) JD JS63C walk-behind mowers
Turftime 60" roller
Turftime 54" 3pt core aerator
Frontier SS1036B Spreader
TJR345 is offline
post #3 of 119 Old 01-05-2014, 08:46 AM
Still lovin' the 322!
PA318Guy's Avatar
Yep looks like you identified all the parts changed out at SN 30001 and above. If you have a TM for your deck and it is current you might find instructions in there for updating it. Also the JD dealer you bought the parts from might give them to you if you ask.
Current Machine JD 322
PA318Guy is online now
post #4 of 119 Old 01-05-2014, 08:56 AM
Jimbochap's Avatar
Curious of the tractor........and what we are all wondering, how much $$$
John Deere X495
54" Mower Deck
Front Hitch w/ 54" Snowblade
Buford Bucket
Click N'Go Bracket
Rear Weight Bar
6 Suit Case Weights
Cast Iron Rear Wheel Weights
JD 345 SOLD
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Jimbochap is online now
post #5 of 119 Old 01-05-2014, 09:23 AM Thread Starter
Here are pics of the tractor, which I bought with the deck for less than $5K.
It has 380 hours, got it from a local repair guy who was flipping it.
He had it for several months, was an end of season deal.
I'll be going through this completely as well as it had no maintenance records.
Eventually I'd like to put on a 3PH and get as blower for it.
I've got the TM PDF for the tractor, which has some information on the deck.
ID:	626666   Click image for larger version
ID:	626674   Click image for larger version
post #6 of 119 Old 01-05-2014, 09:29 AM
TJR345's Avatar
Good deal and low hours looks to be in good shape.
Tom
62"powerflow
12 suitcase weights
JD T105 trimmer
15 gal. tow sprayer
Turftime 60" roller
TJR345 is offline
post #7 of 119 Old 01-05-2014, 10:01 AM
PA318Guy's Avatar
That was a good deal. Shouldn't have too hard a time finding a snowblower for it.
post #8 of 119 Old 01-05-2014, 10:08 AM
RBRONKEMA GHTFD's Avatar
Looks like you got a good deal. How did the repair guy end up with it? Was something broke on it?
07 John Deere X748
54c Deck
Cat. 1 Limited 3pt. hitch
540 Rear PTO
03 John Deere X585
54c Deck w/14 bushel bagger
45 Loader
47 Snowblower
51 Rotary Broom
54 Push Box
Curtis Cab
John Deere 10p Cart
Land Pride CAO556 Aerator
Sold
John Deere x475
48c deck
47 quick hitch blower
02 John Deere x585 rescue project.
RBRONKEMA GHTFD is offline
post #9 of 119 Old 01-06-2014, 12:44 PM Thread Starter
There was nothing wrong with the X585 that I am aware of, other than a questionable maintenance history. Given the shape of the deck the PO did not own a grease gun, so I am assuming worst case.
The guy I bought it off of does tractor repairs and service as well as some small number of trades and sales. He had picked up a X585 and a X595 from someone who was moving up to some bigger equipment. The X595 was even cheaper but it was in tougher looking shape and had a broken hour meter, so no idea of usage. He may still have the X595.
post #10 of 119 Old 01-26-2014, 01:06 PM Thread Starter
Next thing to do was to fix the gage wheels. The originals were severely worn from lack of lubrication, so I ordered the full rebuild kits (AM125172). Note that they don't include the little hubcaps in the kit.
The rebuild kit includes axle bushings that are intended to be bolted on, but my originals were press fitted and swaged together. Using a vice and a large pipe wrench, I was able to twist off the old axles and then drill out for M8 hardware. You will need a drill press to do this and do it in a couple of stages. The swaged steel is rather tough.
Don't even think drilling out the new axle bushings for larger 3/8" hardware as they are hardened. (Don't ask how I know...).
I ended up using M8 x 90mm bolts but the locking flange nuts don't have enough thread to fully lock so I hit them with some red loctite. If using 100mm bolts you might need to cut or grind them down a bit.
post #11 of 119 Old 01-26-2014, 06:20 PM Thread Starter
Now the gearbox...
Note that the drive pulley fits onto a tapered shaft and is retained by a **left** handed bolt. There is no shaft key; its friction driven. You'll need an impact wrench to get the bolt out, and a gear puller to loosen the pulley. I used a couple of short bolts through the holes in the pulley as it took some force to get it loose.
The shafts were cleaned up before the old seals were pulled. I used a drywall screw to get them out; they did not resist much.
I used electrical tape on the keyed shaft so the new seal would not get damaged. New seals were lubed on the inside and tapped in using a large socket.
I am thinking about modifying the drain plug to hold a small magnet.
Have to get my little mini lathe setup first...
This gearbox was supported with rubber bushings that were completely gone, allowing metal to metal contact. I am going to try making some replacement bushings out of polyurethane.
I'll be using that Redline Shockproof Gear Oil to fill it.
post #12 of 119 Old 01-26-2014, 06:28 PM
Can I suggest something,
Take everything completely off of the deck, spindles and everything, so you have nothing but a metal shell. Wet sandblast the entire deck with a pressure washer sandblasting attachment. Repaint with John Deere paint. You CAN rebuild these decks and make them look completely brand new if you dedicate a little time and a little extra money.
JDX740 is offline
post #13 of 119 Old 01-27-2014, 08:13 AM Thread Starter
Thanks for the suggestion, but this is going to be a working deck as I have 2+ acres to mow, so I'm going for the mechanicals first. The original paint is actually not too bad, and would probably clean up with some turpentine. The spindles will be coming off for a rebuild too.
post #14 of 119 Old 01-27-2014, 12:49 PM
burned300's Avatar
The shell don't look all that bad, looks like the paint is holding up good, I've seen some missing patches of paint.
1970 112
1975 200
Gannon Earthgavator graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
John Deere cat 1 plow
Innovative brand, Grapple
burned300 is online now
post #15 of 119 Old 01-29-2014, 08:48 PM Thread Starter
I was asked what parts are needed to upgrade the drive train to the newer style. Here is what I think I ordered. Its most of the parts labeled 300000 and up.
M163991 Later model belt
AM136357 Newer V sheaves (2 required)
TCU27776 Tensioner spring
M139145 Bushing for spring mount (need to modify with grinder and/or dremel)
M146490 flat washer (might need 2, not sure)
19M7803 Longer tensioner pulley bolt
I think that's it.
You can probably use the old spring mount, I suspect the bushing got put in there to save some money and eliminate a custom fabbed part.
Currently Active Users Viewing This Thread: 6 (3 members and 3 guests)
Jere39, Zebra5, cnymowinplowinsailin
