oil light came on? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 35 Old 07-27-2013, 07:17 PM Thread Starter
04zrx's Avatar
oil light came on?
My 420 the oil light came on but I have checked it and it seems to be fine. What is causing this light? I did just install the belly pan..... Can I still mow with it? Should I stop using it untill I figure out what is wrong??
Thanks!
1984 John Deere 420 (sold)
home made 3 pt.receiver hitch
2002 X585 with 45 FEL and 54C deck
extended weight bracket (8)
04zrx is offline
post #2 of 35 Old 07-27-2013, 07:46 PM
SonnyT's Avatar
Re: oil light came on?
check the wire coming from the oil sender that it is still on tight or not broken.
RIP Sonny T.
1954-2015
SonnyT is offline
post #3 of 35 Old 07-27-2013, 07:51 PM
04
from my experience this system used a NORMAL CLOSED
oil pressure switch.
the closed position allowed the light to come on because it
was grounded.
once a certain pressure was reached the light would go out,
because the switch opened up.( no ground )
if you have a multimeter, test the switch not running.
it should ring ( speaker symbol ) when you go from the terminal to ground.
then start the engine, and at idle it should not ring.
hopefully you only have a bad switch.
thank you. boomer ( the used onan engine parts guy )
boomers_influence is offline
post #4 of 35 Old 07-27-2013, 08:50 PM
burned300's Avatar
My 420 oil light would come on at idle, so I wouldn't let it idle , two years later the onan grenaded
1970 112
1975 200
Gannon Earthgavator graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
John Deere cat 1 plow
Innovative brand, Grapple
burned300 is offline
post #5 of 35 Old 07-27-2013, 09:29 PM
burned
was there any oil left in the pan
when that happened?
boomer
post #6 of 35 Old 07-27-2013, 09:43 PM
burned300's Avatar
I always checked and added oil before using, Onan never did smoke, then 15 minutes into cutting BOOM. then most of oil was all aver the tractor and my yard
1970 112
1975 200
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
Brinly cat 0 plow
post #7 of 35 Old 07-28-2013, 11:14 AM Thread Starter
04zrx's Avatar
Burned: so were the two related ? I'll investigate further and see what I can come up with.
Side note: I like how you took care of your "POP". It has me thinking, I really need to also.
thanks for the wise words.
04zrx is offline
post #8 of 35 Old 07-28-2013, 02:44 PM Thread Starter
04zrx's Avatar
I found the problem, seems the wire to the sending unit got severed somehow. I replaced it and magically the light now is not on.
Thanks for all the input guys it is so much appreciated!
04zrx is offline
post #9 of 35 Old 07-28-2013, 02:54 PM
burned300's Avatar
the previous owner was more concerned with a clean tractor, it was spotless clean, when I called him and asked when was the last time hydo fluid was changed, he said "hydo oil??" onan needed an over haul, bearing were worn, I could rock the crank with my hand, no wonder it had no oil psi at idle, glad your was just a wiring issue. two days after that day is when I bought my X720 and sold the 420 "as is"
1970 112
1975 200
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
Brinly cat 0 plow
post #10 of 35 Old 07-28-2013, 05:36 PM Thread Starter
04zrx's Avatar
well I have to keep the 420, I just can't swing or justify spending that kind of money on a tractor.
04zrx is offline
post #11 of 35 Old 02-26-2018, 05:09 PM
inspectorudy's Avatar
I have looked all over my T260 Onan and cannot find an oil pressure sender. Does anyone know where it might be? I looked inside the tin over the filter but there isn't anything in that spot.
inspectorudy is offline
post #12 of 35 Old 02-26-2018, 05:55 PM
Three of my friends
biker3777's Avatar
By the oil filter,deep inside.
Jim
Real Lawn Tractors are Green,Just can't have too many toys,and Free is not Cheap.
1965 Round Fender
216 fitted with model 31 tiller
91 Honda Goldwing that I REALLY like.
Wife of 55 yrs that tolorates me
biker3777 is offline
post #13 of 35 Old 02-26-2018, 05:57 PM
Three of my friends
biker3777's Avatar
Every since you got the new tractor I thought you sent the 420 down the road,glad you kept it.👍👍👍
Jim
1965 Round Fender
post #14 of 35 Old 02-26-2018, 05:58 PM
Kish JD 318/420/430
RussKish's Avatar
inspectorudy,
boomers_influence would know if the T260 ever came in a John Deere LGT, and he would be able to tell you what it was equipped with from the full engine model # and serial number. But take a set of photos of the area around the oil filter, with special attention to the oil filter mounting plate/bracket. That would show if there is a port/tap for a oil pressure switch. Then we can find out if it is easy to add just a switch or you need a plate, gasket, switch. Is the wire still there for the 420 oil dash light?
Russ
Proud Owner of: 318/420/430
RussKish is offline
post #15 of 35 Old 02-26-2018, 06:11 PM
Russ, my problem is that this 420 is a Frankenstein. It has the wiring harness of a B43G engine but now has the T260, Performer 24 engine in it. It ran when I bought it so I did not do a close examination of all the little details. It does not have a VR hooked up on it. I discovered that when taking things off of it. Above the oil filter on the bracket, there is a cap screw and just below that some sort of indentation but no threaded hole. I have no idea what this engine was doing before it landed in this tractor but I do not think it was on a tractor. I figure probably a generator. The solenoid is a standard type that was popular years ago but is still available. The wires to the coil are all spliced and miscolored. I do have a used P218 harness that seems to be intact. Any advice would be a help. Now I know why I quit buying and selling 318's! I'll add 420's to that list next. But God! What a beast!
