"Oily" John Deere problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 09-21-2006, 09:00 AM Thread Starter
Guest
Question "Oily" John Deere LX266 problem
Greetings...
I'm hoping this is a "common" problem and one that is easily fixed. My teenage son, in his infinite wisdom, put about 1/2 gallon of 2-cycle gas/oil mix into my John Deere LX266 lawn tractor about 3 weeks ago. Of course he didn't find it necessary to let me know that. When I now try to start it, it only turns over but doesn't start. Do I need to drain the entire tank now? Can I put in an octane booster to help it fire? Do I need to change out the spark plug and fuel filter? What do I do? Any suggestions would be greatl appreciated!
RobbyR is offline
post #2 of 6 Old 09-21-2006, 09:51 AM
Citizen of Earth
bontai Joe's Avatar
Re: "Oily" John Deere problem
I would think that just spraying a little fresh gas in the carb and deluting what's in the tank with reg. gas would get you started, but I've never had this problem, so I'm not sure. I hope you have educated your son on the difference between 2 cycle mix and regular gas and which gets used where. It's a lot more damage to run straight gas in the expensive chain saw.
If it's FREE, it's for ME!
bontai Joe is offline
post #3 of 6 Old 09-21-2006, 10:04 AM
Once was a Super Member
Wingnut's Avatar
Send a message via Yahoo to Wingnut
It not going to hurt anything or clog the fuild filter.
Add something gas to it and use some started fuild to get the engine to start. Once it starts running it usually won't quit, use most of the fuel up.
Celebrating 41 years of a Drug-Free Elvis! Adventures with Harry Ferguson!
How far you go in life depends on your being tender with the young, compassionate with the aged, sympathetic with the striving, and tolerant of the weak and the strong, because someday in life you will have been all of these.
Lose money while restoring a Farmall F-12 let me show you how!
CLICK HERE
Wingnut is offline
post #4 of 6 Old 09-21-2006, 10:09 AM
I'll never get to 10,000
lt230s's Avatar
RobbyR,
to what Joe said.
Also, the plug may have fouled from the gas being a little "rich" w/ the gas/oil mixture. At least pull it to see what it looks like. Filter should be OK unless the mix he put in was dirty.
Look at this way, if you can get it started, although it's a little late in the season, you could be the neighborhood mosquito control officer until you run out and replace it with regular gas.
John
'66 WH lawn Ranger (in progress-still),
'67 JD 112
'72 JD 110 w/ 39 mower, 43 blade, 37A blower
'73 JD 140 w/ deck
'86(?) Kubota L2550 w/ FEL
'69 JD 112H waiting patiently to come back to life
lt230s is offline
post #5 of 6 Old 09-21-2006, 08:42 PM
10,000 +posts!
glenn27's Avatar
RobbyR---i agree with the others--you've just got a really"over-rich" mixtur like---put in good, fresh gas, and run her....You may have to pull the spark plug and clean her with a little emery-cloth, but that's ok.
Check engine oil-level each time you start it..
Oh--Welcome here to MTF--there are a lot of knowledgeable folks here.....
might just take a little while to fall out of our "orbits' to get back here...
Jimmy Buffett
glenn27 is online now
post #6 of 6 Old 09-23-2006, 03:27 AM
Retired MTF Admin
Ken N Tx's Avatar
Thumbs up Re: "Oily" John Deere problem
RobbyR !!
I agree with the others...check the plug...add more gas...run it out...
Ken N Tx is offline
John Deere 955 Hood problem BunkerHillFarmer John Deere 5 02-18-2011 12:37 PM
John Deere 318 Problem JD318 John Deere Forum 23 06-19-2005 11:02 AM
John Deere Foundation Grants $3 Million to Provide Basic Tools to African Farmers bontai Joe BIG John Deeres 1 06-14-2005 12:16 AM
Deere & Company Enhances Leadership Position in Wholesale Landscape Industry bontai Joe BIG John Deeres 0 05-31-2005 01:19 PM
John Deere Specifications from Chief's links Keweenaw4310 John Deere 1 03-22-2005 09:46 PM
