Strobe Light on JD X729 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 39 Old 11-13-2012, 05:35 PM Thread Starter
Since I don't see a cab in the frorseeable future I decided to make a way to mount a strobe light. To the south of my house is a curve in the road and when I'm at the end of my drives pushing snow I want to be seen when they come around the curve. I may shorten it a bit. Wanted to get it high enough though to be seen and above my head. As you can see I mounted it to the 3PH rocker.
Name:	Strobe light  11 13 12.jpg
ID:	236701   Click image for larger version
Name:	Strobe light bracket 11 13 12.jpg
Just call me Larry
2012 JD X729, 62C deck, 45 loader, 54" front blade, Quick Hitch, Cat 1 3PH, Heavy Hitch. Heavy Hitch Forks. Heavy Hitch Sub Soil Ripper. Heavy Hitch sleeve hitch. 8 JD suitcase weights. 2-50# cast rear wheel weights. 4 home made 63# wheel weights. Front fork frame for 45 loader.
197? Economy Power King Model 1614 with tandem transmissions, hydraulics and 3PH and 48" mower deck.
Thread for 110 RF build https://www.mytractorforum.com/12-john-deere-forum/287161-66-110-rf-rebuild.html
1966 JD 110 RF, 580 TracVac, Home built log splitter, Stihl MS260 Pro Chain Saw,
Stihl BG85 Leaf Blower, Echo GT2400 Weed Whacker, 20KW Generac standby generator.
KWDAILYD is online now
post #2 of 39 Old 11-13-2012, 07:35 PM
MI GT's Avatar
Re: Strobe Light
Looks good Larry.
Does look a little high, but airplanes will see it also.
Been toying with the idea of putting one on mine, get some real
idiots on my rode in bad weather, sometimes I'm out before light
or after dark.
Won't be long now, we got a dusting last night, then the stories will start.
Always like to read what others have done. ( good and bad)
Jim
2014 1025R 7 Iron deck auto connect& Mulch kit,with Gator blades.
H120 FEL 53" bucket and Ken's bolt on hooks.
RB2060 60" rear blade
I-Match
Ballast box w/ 600# pea stone
Super Heavy Hitch
8 suitcase weights
2 75# Starter wheel weights and 4 50# add ons
25 gal. tractor mounted sprayer
42" Brinley sweeper
Stihl 026 Pro saw
Stihl blowers and trimmers
It's a good day when the police don't come
to the door and I didn't have to hide any bodies.
MI GT is offline
post #3 of 39 Old 11-13-2012, 07:59 PM
10,000 +posts!
Mike X485's Avatar
Re: Strobe Light
Larry, I'm curious on how you are going to use suitcase weights on the rear with that setup?
JOHN DEERE X748
Mike X485 is offline
post #4 of 39 Old 11-13-2012, 08:03 PM Thread Starter
Re: Strobe Light
It's all 1/2" black pipe and fittings. I just bought a 5' length from Menards and installed it to see what it looked like but I think I will cut it down some.
Just call me Larry
Thread for 110 RF build https://www.mytractorforum.com/showthread.php?t=287161
post #5 of 39 Old 11-13-2012, 08:06 PM
MXZRXP's Avatar
Re: Strobe Light
can never be too safe!
looks good-
2017 1025R with 120R loader, 47" Blower and Curtis Cab
STX38 (yellow deck)
345 48C Deck, 42" Blower, Curtis Cab (sold)
345 Blower in action here:
http://www.youtube.com/watch?v=8dyoup-StaA
MXZRXP is offline
post #6 of 39 Old 11-13-2012, 08:10 PM
Re: Strobe Light
Here's my version. It plugs into a 12V socket that I mounted in the "toolbox" to the right of the seat. The mounting system still lets me use the tow hitches. I'll be removing the tow hitches soon and installing a weight box (80 pounds) on the rear for the winter season.
Skip Douglas - X500 (2006)
SkipD is offline
post #7 of 39 Old 11-13-2012, 08:11 PM Thread Starter
Re: Strobe Light
I thought about that. If I need more weight I'll have to do something else. I have been using a GT225 with just wheel weights and did ok. This X729 ought to be better than thr GT225.
Just call me Larry
post #8 of 39 Old 11-13-2012, 08:17 PM Thread Starter
Re: Strobe Light
I like it. Kind of the same idea. The X729 has a 12 volt socket already in the tool box.
Just call me Larry
post #9 of 39 Old 11-13-2012, 08:28 PM
JD X728's Avatar
Re: Strobe Light
Sure, someone had to ask.
Jerry
JD X728 is offline
post #10 of 39 Old 11-13-2012, 08:36 PM Thread Starter
Re: Strobe Light
Jerry
LOL! It has 5/8 rod running through the 1/2" pipe and just pins to the rocker so iut comes off in 5 minutes.
Just call me Larry
post #11 of 39 Old 11-13-2012, 08:39 PM Thread Starter
Re: Strobe Light
Doesn't Deere make a rear bolt on hanger for suitcase weights so you don't need the 3PH. Don't know if this would be in the way of that, haven't seen one but thought I saw it in the accessory book.
Just call me Larry
post #12 of 39 Old 11-13-2012, 08:59 PM
JD X728's Avatar
Re: Strobe Light
Ok, I stand corrected.
Now lets talk about what will work for everyone. I noticed that you have some holes in the frame that you have not used. Have you thought about this. Make a strap with holes to mount to the frame. Extent the strap 3/16 or 1/4" thick by about 3" wide and long enough to get the job done, far enough to the rear of the tractor so that the shaft of the pole can also be mounted. Then procede as usual to wire it up. The good thing about this solution is that you can offset the bracket enough to clear the arm on the 3 pt hitch. That should work out fine.
I hope you didn't think me rude to pick on your design.
Jerry
JD X728 is offline
post #13 of 39 Old 11-13-2012, 09:07 PM
MI GT's Avatar
Re: Strobe Light
Need the click and go brackets then the weight carrier.
This is what I have and trying to think of a clean way
of making a mount for a strobe.
Not a lot of room left after the weights are hung.
Jim
I-Match
Super Heavy Hitch
8 suitcase weights
42" Brinley sweeper
Stihl 026 Pro saw
MI GT is offline
post #14 of 39 Old 11-13-2012, 09:44 PM
Dan33Klein's Avatar
Re: Strobe Light
Looks good!!
2014 Kubota 2370-1
LA243 FEL
54" MMM
2000 John deere 455 Diesel. SOLD
Mini FEL
Ruegg Cat 1 Limited 3 Point hitch
60 Inch Commercial Deck
1987 John Deere 214 RESTORED. SOLD
37A Blower RESTORED
1979 John Deere 317 Briggs Re Power RESTORED. SOLD
54" 4 Way Hydraulic Plow RESTORED
https://www.mytractorforum.com/showthread.php?t=178233
https://www.mytractorforum.com/showthread.php?t=214280
Dan33Klein is offline
post #15 of 39 Old 11-13-2012, 09:50 PM
396 big block's Avatar
Re: Strobe Light
Always good to be seen!!
Marty 2012 John Deere X500, 1970 John Deere 120
1972 John Deere 140 Acts 10:34 34 Then Peter opened his mouth, and said, Of a truth I perceive that God is no respecter of persons:
396 big block is offline
