Pulling capacity for X500 john deere? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 24 Old 11-05-2012, 06:17 PM Thread Starter
Wondering how much would be OK for my X500 to pull in lawn maintenance work. I have a trailer with a 1200 pound load limit. Don't want to hurt the trans or engine. Any thoughts?
parsonbw is offline
post #2 of 24 Old 11-05-2012, 07:37 PM
MXZRXP's Avatar
Re: Pulling capacity for X500 john deere?
you don't want to pull anything that weights more than the tractor very often, or it will push you downhill or even on flat if t weighs enough...
assuming a 1200 lb load limit means it is probably closer to 1850+ with the weight of the trailer WAY to much for a x500 series to be able to stop. It will pull it just fine!
Now if just for a single move, going very slow on flat surface, probably can get away with it.
I used mine to move my sea-doo trailer with sea-doos on it, weighs over 3000 lbs. it pulls it just fine but stopping is another matter. I was on flat ground and drove only 1-2 mph for 200'... not advised but if you are careful you can make it work assuming a properly balanced trailer with little tongue weight...
2017 1025R with 120R loader, 47" Blower and Curtis Cab
STX38 (yellow deck)
345 48C Deck, 42" Blower, Curtis Cab (sold)
345 Blower in action here:
http://www.youtube.com/watch?v=8dyoup-StaA
MXZRXP is offline
post #3 of 24 Old 11-05-2012, 08:18 PM
396 big block's Avatar
The older 140's must have a better tranny? I have seen them loaded with some serious weight's on the back of them! The x500's can handle a 18 metal & 17p cart seems like a pretty decent load. JD 18 steel cart 1650 lbs according to JD website..
Marty 2012 John Deere X500, 1970 John Deere 120
1972 John Deere 140 Acts 10:34 34 Then Peter opened his mouth, and said, Of a truth I perceive that God is no respecter of persons:
396 big block is offline
post #4 of 24 Old 11-05-2012, 08:19 PM
The Travelin' Mod
davidg's Avatar
on flat ground the X500 won't even know it is there except when stopping. i pulled a pecan tree log with mine. 15' long, 3' across at the big end and a little over 2' across at the small end i don't know the exact weight but it was easily close to what you are asking, and this was dead weight being dragged. I was not even at WOT, though i should have been for tranny cooling purposes. the X never even grunted.
common sense should prevail anytime you are pulling/towing. make sure you have plenty of room to stop and never tow anything dowhill that weighs more than the tractor can stop. if it has a hard time stopping it on flat ground, it has no chance on even a small hill.
Check out our new HOMEPAGE
davidg is online now
post #5 of 24 Old 11-05-2012, 09:35 PM
Run ahead of the pack
stladrill's Avatar
The X500 can pull, but braking capacity is the weak part.
K72 specification
Wanna see Nice John Deere and Kioti Video?
Just click YouTube below
stladrill is offline
post #6 of 24 Old 11-06-2012, 08:31 AM Thread Starter
I appreciate the quick responses. I was assuming that a 1250 pound plus the weight of the trailer (150lb) would not hurt the mower. I will not be pulling or stopping on extreme grades, it's all in my home yard. If need be, I can stop short of loading to capacity. I'm new to the X500, and am learning it's capabilities.
Don't mean to start another thread, but what plugger would you recommend? I have a great aerator, but would like to get a plugger. I am in a new home that was only built Dec. 2011, so the yard will be four or five years out before it looks great. My land is what we in the south call "buck tallow", old yellow and red clay that you could use for silly putty. I'm using K-31 grass seed, and has done fairly good for one application. Didn't mean to start new thread, but I guess I did.
parsonbw is offline
post #7 of 24 Old 11-06-2012, 08:57 AM
Nouveau Redneck's Avatar
Pulling that much around a flat yard shouldn't hurt anything. I pulled a 3600 lb. rental wood chipper around my property a couple of years ago with no ill effects. I regularly pull my little cart around my yard loaded with wood, which is usually around 700 to 1000 lbs, depending on the type of wood. I've pulled my larger trailer around full of wood as well, and that's around 2000 lbs. full. Just go slow and give yourself plenty of slowing down room when coming to a stop.
Be sure to change the hydraulic fluid at 50 hours, and at least every 200 hours thereafter. I changed mine at 50, and I'm planning to change every 100 to 125 hours from now on, just to be nice to it, and because I would go for too many years if I waited for every 200 hours, probably close to 4 years a the rate I'm going. Most oils will get water in them from condensation over time, and I figure changing it at least once every 2 years will cut down on long term internal contamination and rust issues.
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is offline
post #8 of 24 Old 11-06-2012, 04:38 PM
You will run out of traction before you run out of power if pulling something like a log or sliding load. But anything on wheels like a trailer, you better not pull more than what the tractor weighs or you won't be able to stop it. It's not the brakes themselves, but a traction issue.
Engine_Tech is offline
post #9 of 24 Old 11-06-2012, 04:46 PM
stladrill's Avatar
Exactly.
post #10 of 24 Old 11-06-2012, 04:47 PM
K72 specification
Are specs like these available online for all the Deere's?
Just call me Larry
2012 JD X729, 62C deck, 45 loader, 54" front blade, Quick Hitch, Cat 1 3PH, Heavy Hitch. Heavy Hitch Forks. Heavy Hitch Sub Soil Ripper. Heavy Hitch sleeve hitch. 8 JD suitcase weights. 2-50# cast rear wheel weights. 4 home made 63# wheel weights. Front fork frame for 45 loader.
197? Economy Power King Model 1614 with tandem transmissions, hydraulics and 3PH and 48" mower deck.
Thread for 110 RF build https://www.mytractorforum.com/12-john-deere-forum/287161-66-110-rf-rebuild.html
1966 JD 110 RF, 580 TracVac, Home built log splitter, Stihl MS260 Pro Chain Saw,
Stihl BG85 Leaf Blower, Echo GT2400 Weed Whacker, 20KW Generac standby generator.
KWDAILYD is online now
post #11 of 24 Old 11-06-2012, 06:21 PM
proud qwner
jimbox748's Avatar
k92 specs for your X729...
Name:	K92 CHART.jpg
2011 x748
60" 7-iron deck
54" snowblower
54" blade
past machines:
cuc cadet gt1554(junk)
1973 case 220 (sold)
jimbox748 is offline
post #12 of 24 Old 11-06-2012, 06:49 PM
stladrill's Avatar
They are specification from Tuff Torq.
Link Here for all Tuff Torq transaxle.
post #13 of 24 Old 11-06-2012, 07:05 PM Thread Starter
Thanks, Men.
parsonbw is offline
post #14 of 24 Old 11-06-2012, 08:30 PM
Thanks STLADRILL
Just call me Larry
Thread for 110 RF build https://www.mytractorforum.com/showthread.php?t=287161
post #15 of 24 Old 11-06-2012, 09:09 PM
stladrill's Avatar
Originally Posted by parsonbw View Post
Thanks, Men.
Thanks STLADRILL
