X 485 Fuel Injector Problem? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 11-08-2019, 12:26 PM Thread Starter
Hello;
I have a 2003 JD and have a fuel problems with it, maybe the injectors?
Is there a reasonable life expectancy on this part, and also the computer?
When starting hot, if you take off the air cleaner off and spray ether in it, she will fire right up. Trying to get this nailed down before winter.
Looking for a way to test them. Already ran the one test to see if they "click" and yes they both are .
All the best
CorkyK is offline
post #2 of 7 Old 11-08-2019, 12:32 PM
burned300's Avatar
Re: X 485 Fuel Injector Problem?
I wonder if John Deere going to a solid fuel cap on tractors like x720 helped keep fuel pressure so the fuel would not vaporize like the X485s
Sent from my iPhone using Tapatalk Pro
1970 112
1975 200
Gannon Earthgavator graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
John Deere cat 1 plow
Innovative brand, Grapple
burned300 is online now
post #3 of 7 Old 11-08-2019, 10:17 PM Thread Starter
Burned;
Are you saying that a gas cap modification to the X 485 will make things right?
CorkyK is offline
post #4 of 7 Old 11-08-2019, 11:36 PM
summers5's Avatar
The x4 and x5's had alot of problems with the fuel pump hose coming loose or off. Plus theres a filter at the end of that hose in the tank that can cause problems. My old x485 had the filter break loose. I thought all the caps were vented but i could be wrong.
1997 Sears GT 18.5hp"Kohler Magnum"
SplitFire Plugs
46" Deck
Led tail lites
Electric deck-hitch kit
Sears grader blade
Ag-Fab Spreaderare
46" 2 stage SnowBlower 55w lites
Weights and chain
2005 JD X485 25hp(SOLD)
2008 Echo-SRM230 Trimmer 22.8cc
2010 Echo-PB500T Blower 50.8cc
2007 JD X748SE
54" Edge Deck
3 Point(Ruegg)Hitch Cat1
54" 4way Blade
Yanmar 3TNV76 1116cc 24hp
JD 45 Loader
Heavy Hitch
Front pto
summers5 is online now
post #5 of 7 Old 11-09-2019, 08:06 AM
burned300's Avatar
Originally Posted by CorkyK View Post
Burned;
Im not going to say that, it just makes me wonder if it helps, when I shut off my 485 Id raise the hood for the heat would escape and not heat up the fuel
1970 112
1975 200
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
Brinly cat 0 plow
post #6 of 7 Old 11-09-2019, 09:36 AM
Jimbochap's Avatar
The vibration makes the fitting come loose out of the fuel filter assembly. Same thing happened on my X495..........It's about $60 to replace the whole thing, comes with a filter also. Easy fix.
John Deere X495
54" Mower Deck
Front Hitch w/ 54" Snowblade
Buford Bucket
Click N'Go Bracket
Rear Weight Bar
6 Suit Case Weights
Cast Iron Rear Wheel Weights
JD 345 SOLD
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Jimbochap is offline
post #7 of 7 Old 11-09-2019, 12:39 PM
Carlos's Avatar
I had a 2005 X485. Got it with 33 hours on it and two years old. It developed an intermittent miss. You could not get off the tractor to diagnose it. Yes, I also noticed the harder to start after running. Raising the hood would cure that irritation. So I could stop for lunch and not have it stumbling for a couple minutes.
I checked the short hose on the fuel pump. Replaced the fuel pump which comes with a screen filter. That was pricey. Changed plugs and fuel filters a number of times. Pulled apart all connections, cleaned and greased them. Adjusted valves. Blew air through the fuel cap. Always used Stabil.
Finally lost spark on one side at 800 hours. Replaced & gapped the ignition coils. Ran perfectly smooth and made good power. The new coils are marked 1 & 2. They are not interchangeable.
Neighbor talked me out of the X485 and I bought a low hour X750 diesel.
Carlos is offline
