Looking for battery replacement for my '15 X590 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 29 Old 11-07-2019, 08:04 PM Thread Starter
whitecrystal1's Avatar
Is an AGM battery overkill? I did get slightly over 4 years on my OEM battery. Looking for recommendations for what to get. Thanks, Ralph
2015 John Deere X590 Kawasaki 25.5HP EFI 54" deck
.......* 30" Mechanical Tiller, 47" Snowblower, 100lb Rear Wheel Weights, Mulch Kit, Brush Guard, Seat Armrest
.......* 1.5 Amp Battery Charger/Maintainer, Lawn Sweeper W/Dethatcher, 36" Drum Plug Aerator
.......* Rubbermaid 15 cu. ft. 1500 lb. Heavy-Duty Structural Foam Tractor Cart, HDAP Tires
.......* tractorace09 2" Rear Receiver & Hitch, LED Headlights & JWalter's Rear tail Light Kit
2016 Honda HSS724ATD 198cc 24" Two-stage Track drive Snow Blower
.......* Deltran .75 Amp Battery Tender Jr., FallLine Polyurethane Skid Shoes
2014 ECHO SRM-230 22.8cc 17" Straight Shaft Trimmer
whitecrystal1 is online now
post #2 of 29 Old 11-07-2019, 08:33 PM
Re: Looking for battery replacement for my '15 X590
I go AGM in whatever i can. Motorcycles, lawn equipment, deep cycle boats batteries, etc.
They last longer, tolerate discharge better and resist vibration better. It's also nice being able to mount an AGM in any orientation you need too. For example, when I swapped a VMAX engine in my Yamaha venture, the taller carb assemblies took up most of the battery space. Because it was an AGm, I was able to place it on it's side and mount it to the bike.
I'm a little bias I guess, I jumped on the AGm bandwagon and haven't looked back. They do cost a bit more than "regular" lead acid batteries though....
Great white is offline
post #3 of 29 Old 11-07-2019, 08:41 PM Thread Starter
I have been swapping to AGM on everything as well. I just don't know what are my options for this machine. It seems very limited. Maybe I am missing something. Thanks
post #4 of 29 Old 11-07-2019, 09:17 PM
jgayman's Avatar
I'm going on 7 years with the original OEM battery in my X500. My previous JD 175 Hydro went 9 years on the original battery. AGM batteries are the way to go if you are using them under conditions that warrant them but quite frankly a garden tractor isn't one of them. Also, I think if you check the warranty on AGM batteries you'll find it not much different than that of a wet cell lead-acid.
I've stuck with the JD OEM battery in my garden tractor and 2720 CUT and for the price they do just fine.
The X590 battery is 500 CCA, Group 51.
jgayman is offline
post #5 of 29 Old 11-07-2019, 09:25 PM
My GT has a winch, which taxes the battery pretty hard. AGm lets me run it down and charge it back up. It's abuse that a "flooded" battery won't tolerate/survive as long under.
But if You're just cutting grass, you can get away fine with a flooded acid battery. Just keep a battery tender on it to maximize it's life.
post #6 of 29 Old 11-07-2019, 09:29 PM Thread Starter
I do wish my OEM battery would have lasted that long. I know my options are limited. I am looking for recommendations. Thanks, Ralph
post #7 of 29 Old 11-07-2019, 10:33 PM
Jimbochap's Avatar
John Deere Dealer TY25876 , take the core back for a refund.
John Deere X495
54" Mower Deck
Front Hitch w/ 54" Snowblade
Buford Bucket
Click N'Go Bracket
Rear Weight Bar
6 Suit Case Weights
Cast Iron Rear Wheel Weights
JD 345 SOLD
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Jimbochap is online now
post #8 of 29 Old 11-08-2019, 12:31 AM
Murph
bmurph44's Avatar
Walmart batteries for me, they last as long as anything I've purchased plus I can buy two of them for the price of one Interstate or Deere brand.
John Deere X540
48 Inch Blade
44 Inch Snow Blower
Encore Z48 Zero Turn
Dixon Ram 50 Zero Turn
bmurph44 is offline
post #9 of 29 Old 11-08-2019, 08:56 AM
AGM is definitely not overkill. Interstate batteries are sold at costco for a pretty good price if you happen to be a member, otherwise the everstart brand from walmart is a decent battery and comes with a good warranty (usually 3 year replacement, 2 year pro rata or something to that effect). I have never used a warranty, but its nice that its there. Both those options are probably cheaper than the AGM, but I haven't priced them out.
EDIT. Now that I am looking, I am not seeing an AGM that would fit? I can only find an ac delco on amazon or a duralast from autozone, neither of which are something I would consider.
winkeldc is offline
post #10 of 29 Old 11-08-2019, 10:23 AM
Take you battery into batteries plus. Ask for a replacement AGM. I prefer Duracell in AGM.
Swazimoto is offline
post #11 of 29 Old 11-08-2019, 10:30 AM
jgayman's Avatar
The Duracell and Optima AGM Group 51 batteries are less CCA than the Deere battery.
jgayman is offline
post #12 of 29 Old 11-08-2019, 10:53 AM
This is often true CCA450 / CA to 555 is common on AGM batteries in this size. Optima included in those numbers. However, this number is excellent condition batteries. LA will deteriorate faster and still work a long time but have way less CCA. Overall you get consistently higher CCA with AGM in my experience. 450 is adequate oomph.
post #13 of 29 Old 11-08-2019, 11:03 AM
RT3360's Avatar
I found AutoZone has very good options. I bought a U1-3 AGM battery to get the higher CCA/CA at very good price under $50.
The AGM is still a lead acid. It just has the glass mat that holds the acid and makes the battery more rugged.
JD Ztrac 757 60”
Craftsman DLT2000, 48”
RT3360 is online now
post #14 of 29 Old 11-08-2019, 11:50 AM
Hummer.2012's Avatar
So what would be the expected life of an AGM battery?
Sent from my SM-G900R4 using Tapatalk
2014 - X758SE w/Block Heater, Rear PTO, 3-point, 54"HC Deck
2013 - Heavy Hitch w/sleeve hitch option, 647 Tiller
2013 - Ohio Steel core aerator, curtis cab w/heater
2012 - JD X748SE w/Block Heater, Bercomac 48" Snow Blower
2012 - 60" 7-Iron Mower ,3-point, Rear PTO, IMatch
Help support White Paws German Shepherd Rescue when you order from Amazon. Click here to find out how.
Video:
http://www.youtube.com/watch?v=y_3ss8GsSlo
Hummer.2012 is offline
post #15 of 29 Old 11-08-2019, 02:45 PM
RT3360's Avatar
Generally I get 7-10 years. Long enough for me to not remember clearly the last time.
JD Ztrac 757 60”
Currently Active Users Viewing This Thread: 13 (5 members and 8 guests)
PEIDeerefan, RT3360, Robert Post, bogart7456, royalton10
