x300 not starting...video - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 11-05-2019, 08:34 PM Thread Starter
I believe its a 2007 and has 2100 hours on it. It was given to me for free in the summer of 2018 so I couldnt say no. Air filter, oil, filter, spark plug and fuel filter changed in 2018. It ran fine all last summer and this whole summer as well. Replaced the battery 2 months ago.
She really has been trouble free expect for the belt jumping off when I lower the deck below 2.5". Cant figure that one out
Last weekend I started her up, backed her out the shed and was attemping to clean it up for winter storage. I may have gotten water from the hose somewhere that I shouldnt have but she wouldnt start up after I was done cleaning. The noise in the video is what you hear. Can anyone diagnose that based off the noise?
anthony21078 is offline
post #2 of 16 Old 11-05-2019, 11:40 PM
jgayman's Avatar
Re: x300 not starting...video
Sounds like a starter problem. It sounds like the starter motor is spinning but not engaging the bendix gear. Remove the plastic shroud on the engine and that will expose the top of the starter where it engages the flywheel. I think you'll know more after you see what's happening there.
jgayman is online now
post #3 of 16 Old 11-05-2019, 11:57 PM
oldgibsonguy's Avatar
It's a bad starter solenoid. Replace the starter.
John Deere X738 4wd
48" mower deck
In use - Kubota G2000-S 52" deck, 21HP 3 cylinder gas, hydraulic lift
SOLD - X580 fully equipped
Retired - Craftsman GT18
oldgibsonguy is online now
post #4 of 16 Old 11-06-2019, 12:07 AM
jgayman's Avatar
I don't believe these starters have a solenoid. A new starter is very expensive. I would take it off and have a look at the bendix. It may just be binding.
ID:	2404963   Click image for larger version
post #5 of 16 Old 11-06-2019, 07:39 AM
The solenoid function is built into the starter, hence my statement. These starters are similar to the old Dodge high speed starters where centrifugal force moved the pinion forward to engage with the flywheel. Not really a solenoid, just old school reference to that section of the starter.
John Deere X738 4wd
48" mower deck
post #6 of 16 Old 11-06-2019, 07:53 AM
Blank Space
Just look through the top of the fan/screen (top of the engine) and he should be able to see if the fins are turning or not.
LS MT125
Obscured_by_Clouds is offline
post #7 of 16 Old 11-06-2019, 09:26 AM
jgayman's Avatar
You can already see in the video that the flywheel is not turning but you can hear the starter motor turning yet it is not engaging the bendix gear. The problem is definitely the starter. It may have something broken or the bendix gear may just be stuck. It happens. Once he removes the shroud he should be able to see what the bendix is doing. It may just need to be tapped gently with a hammer. Either way, the shroud has to come off. It's very easy to do as it's only held on by a few bolts.
An OEM starter will cost over $200 but I saw some 3rd party replacements advertised for around $66.
I wouldn't recommend spending the money on a new starter until you verify why the old one isn't working.
post #8 of 16 Old 11-06-2019, 01:52 PM
Father Deerest
I agree with what everyone is saying with the exception that the starter is spinning so that's not the problem just the gear isn't engaging. Take the top off the starter and clean the bendix use a light oil to get it all spinning again, it's an easy fix just take your time and inspect all parts and re-assemble, no money involved just simple hand tools and time.
Father Deerest is offline
post #9 of 16 Old 11-06-2019, 04:56 PM
Yup, no need to buy a starter just yet. Take off whatever's in the way of you having a clear view of the starter drive and have a look while you or a helper turn the key. As stated by others, it's likely a little light lubrication will free up the pinion gear so that it can travel upwards and mesh with the flywheel ring gear.
dixie460 is offline
post #10 of 16 Old 11-06-2019, 05:39 PM
I agree to this. 1/2 hour of work, 2 beers, and a can of WD40. Just be sure to disconnect the battery before you do ANYTHING.
John Deere X738 4wd
48" mower deck
post #11 of 16 Old 11-06-2019, 07:56 PM
Father Deerest
Definitely safety first!! Bring the beer closer so you don't stumble and fall.... oh yeah and the battery
post #12 of 16 Old 11-06-2019, 10:30 PM Thread Starter
Appreciate the suggestions. I wont be able to get out there until the weekend but I will report back what I find
On another note, any ideas why the belt falls off when I lower the deck below 2.5" ?
post #13 of 16 Old 11-07-2019, 12:47 AM
jgayman's Avatar
If you disconnect the battery you won't be able to observe the starter in operation.
post #14 of 16 Old 11-07-2019, 07:55 AM
That's correct Sherlock. Why does that matter when you're pulling it out to attempt a repair? Maybe to destroy some other electrical component, start a fire, hurt yourself? At least disconnect the battery while you pull out the starter. It can be re-attached after the starter is out of the tractor if absolutely needed.
John Deere X738 4wd
48" mower deck
post #15 of 16 Old 11-07-2019, 09:39 AM
RT3360's Avatar
By the way, you only need to disconnect the ground wire from the battery.
JD Ztrac 757 60”
Craftsman DLT2000, 48”
RT3360 is offline
