X485 with a 47" Snowblower - weights needed? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 18 Old 11-02-2019, 10:49 AM Thread Starter
jacobsed's Avatar
Hi,
X485 with a new to me 47" Snowblower I'm using this season. I have tire chains and wheel weights also. Based on your experiences do I need anymore weight on the back?
Thanks!
jacobsed is offline
post #2 of 18 Old 11-02-2019, 12:20 PM
badgerland01's Avatar
It really depends on your situation. Most of the time I could get by with loaded tires, a heavy homemade wood cab, and no chains. Occasionally I added more weight on the rear to handle slick conditions. You can probably manage with the wheel weights and chains, but there will be wheel slippage. Chained wheel slippage on hard surfaces will result in scratches to the driveway surface. More weight will reduce wheel slippage. So it is up to you and the experience you want to have out in the cold.
badgerland01 is offline
post #3 of 18 Old 11-02-2019, 12:50 PM Thread Starter
jacobsed's Avatar
I’d like to have a great experience! Any recommendations on weight and exactly what to buy?
jacobsed is offline
post #4 of 18 Old 11-02-2019, 01:25 PM
gt275's Avatar
Re: X485 with a 47" Snowblower - weights needed?
This is what I have on my x485. Used for loader work.
Bracket was purchased from a seller on ebay and weights are from JD. I think it was approx $150.
ID:	2404429   Click image for larger version
ID:	2404433   Click image for larger version
ID:	2404435   Click image for larger version
2004 X485 (4/15) 25hp Kawasaki, 62" deck, 45 Loader, Front-mount de-thatcher.
2005 GX345 (11/09 124hrs) 20hp V-twin liquid cooled Kawasaki, 54" deck, Differential lock, Femco Cab Weather Enclosure, 42" snowblower, Electric Spout Rotation Kit.
1998 345 (08/19 627hrs) 18hp V-twin liquid cooled Kawasaki, 54" deck.
-SOLD-
2001 345 20hp V-twin liquid cooled Kawasaki, 54" deck
1998 GT275 17hp Kawasaki, 48" deck, Cab Enclosure, 38" Snowthrower, Manual Spout Kit
1997 LX188 17hp Kawasaki, 48" deck
gt275 is offline
post #5 of 18 Old 11-02-2019, 01:30 PM
If using suitcase weights, you will need a weight bracket and 6 weights. It is a bit of a balance between steering and traction when using rear weights. Too much rear weight can equal not enough traction. Not enough weight equals not enough traction. This is why suitcase weights are so nice. You can easily adjust the weight to find the sweet spot for your needs. The price is going to buckle your knees a little tho. Welcome to owning a John Deere!
X749 "H-3 EDITION"
GX345
post #6 of 18 Old 11-02-2019, 01:31 PM Thread Starter
jacobsed's Avatar
Do you have the link to the eBay bracket? Is there an alternate case weight that is cheaper than JD?
jacobsed is offline
post #7 of 18 Old 11-02-2019, 01:41 PM
gt275's Avatar
This is the cheaper alternate bracket that I'm showing. The ebay seller is absolutemetalworks.
The JD bracket requires the BM20714 Click-N-Go bracket which drives the price up, almost twice as much.
-SOLD-
gt275 is offline
post #8 of 18 Old 11-02-2019, 03:43 PM
20,000 Posts & Climbing
I experienced wheel spinning only with aggressive drive use on my MF1655 with a 48" blower.
- Loaded tires (Rim Guard) - 280 lb
- Wheel weights - 80 lb
- 5' back blade (with 150 lb added weight) on the 3PH - 250 lb
- Tires - Carlisle Multi Trac C/S (Turfs)
- 2-link chains - 30 lb
Total added weight for traction - 640 lb
Good traction on glare ice and frozen asphalt, excellent traction on hard packed snow.
The back blade is a for countering the weight of the blower out front and was usually on the ground cleaning up when the blower was doing it's thing. Take off the back blade and traction did become slightly problematical when transporting the blower.
My heavier 4wd SCUT using the same tires without chains is slightly less potent than the 2wd GT with chains. It has no wheel weights and a lighter 5' back blade, but it can climb a 20° icy slope with a full bucket of heavily compacted wet snow and ice.
TUDOR is offline
post #9 of 18 Old 11-02-2019, 05:03 PM Thread Starter
jacobsed's Avatar
$150 for the ebay bracket is not bad. But how much are the case weights? Is there a best and cheapest option?
jacobsed is offline
post #10 of 18 Old 11-02-2019, 05:33 PM
-Used is the cheapest option at around $40-$50 each. Dealer and home depot or Lowes are also an option at $65 or so each. There are other options but shipping usually cuts into most of the savings.
X749 "H-3 EDITION"
GX345
post #11 of 18 Old 11-02-2019, 06:03 PM
Jimbochap's Avatar
Blower needs less weight on the back then a plow does, you are just throwing the snow out of a blower, not pushing the weight of the snow.
John Deere X495
54" Mower Deck
Front Hitch w/ 54" Snowblade
Buford Bucket
Click N'Go Bracket
Rear Weight Bar
6 Suit Case Weights
Cast Iron Rear Wheel Weights
JD 345 SOLD
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Jimbochap is offline
post #12 of 18 Old 11-02-2019, 06:16 PM
gt275's Avatar
We just got 7 1/2" of heavy wet snow and pushing it with the blower was the only way to move it. It was so sticky it wouldn't even go into the blower. I had no problems pushing it with my gx345. In fact it was all uphill.
I have a cab, chains and 3 suitcase weights on it, but can add up to 5 if needed.
-SOLD-
gt275 is offline
post #13 of 18 Old 11-02-2019, 09:53 PM
Jimbochap's Avatar
I'm confused as to which tractor has which attachment and which one couldn't blow wet snow ?
My 345 with flapper mod could move wet snow, no problem, just like shooting out snow cones...........heck it could even throw water puddles out the the blower spout.
John Deere X495
54" Mower Deck
Buford Bucket
Click N'Go Bracket
Rear Weight Bar
6 Suit Case Weights
JD 345 SOLD
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
post #14 of 18 Old 11-03-2019, 01:04 AM
celltech's Avatar
I was in your exact same boat last winter. X720 w/47" blower, wheel weights and Terra grips.
Traction was NOT a issue most of the time however it did happen. Needless to say I bought the JD weight bracket and 6 suit case weights from greenstore.com and used TTWT promo code for free shipping.
Already got to try it out a few weeks ago. Works awesome and no more slippage.
2010 John Deere X720 w/ 48" deck and 47" snowblower
2000 Lawn Boy Silver 10323
1998 Lawn Boy Gold Pro 10547
1997 Lawn Boy Gold 10518
2014 Ariens Deluxe 28+ 921035- Sold
1989 Toro 824- Sold
celltech is online now
post #15 of 18 Old 11-03-2019, 07:15 AM
mikgran's Avatar
X2.
While my X485/47 blower is a beast when it comes to moving deep snow and snow banks, my 345/3252 SS blower was better when working with wet snow or deep slush.
2004 X485- 54 deck, 47 blower
1977 210
1970 110H
1991 Ariens YT12H w/bagger
1986 Kubota B7200HST
mikgran is offline
