JD216 belt issue - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 10-18-2019, 04:20 PM Thread Starter
JD216 belt issue
My ancient 216 just shredded the primary drive belt and I can't figure out why. The belts are only 2 years old with average use. The secondary belt was spared and was not affected. I;m piurchasing new belgts but before I replace them I am quite ingterested if there is anything I need to look at and address. Thoughts? Thanks
gowinlions is offline
post #2 of 7 Old 10-18-2019, 04:22 PM
burned300's Avatar
Re: JD216 belt issue
using Deere belts?
1970 112
1975 200
Gannon Earthgavator graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
John Deere cat 1 plow
Innovative brand, Grapple
burned300 is offline
post #3 of 7 Old 10-18-2019, 07:53 PM Thread Starter
Yes, all belts are Deere.
post #4 of 7 Old 10-18-2019, 08:09 PM
B440's Avatar
All the engine mounts are good?
B440 is online now
post #5 of 7 Old 10-18-2019, 08:13 PM Thread Starter
I haven't checked but they are the original, I do know that. I just got done removing the variator and noticed the middle sheave is quite wobbly. That would explain the speed problems I've been having.... Can I assume this was the problem for the belt shredding as well? And should I replace the motor mounts just in case? Thanks
post #6 of 7 Old 10-18-2019, 08:58 PM
A wobbly variator is definitely hard on the belts. Years ago I had a combine with a similar variator belt drive system, and it started going through belts at an alarming, expensive rate. I repaired the wobbly variator and my belt problem quit.
1969140 is offline
post #7 of 7 Old 10-19-2019, 08:56 AM
B440's Avatar
If try to move the engine around, and see cracks in the mounts, then you may want to replace them. They throw the belt out of alignment and cause abnormal belt stretching. Mine need replacing soon.
B440 is online now
You may post new threads
You may post replies
