H2 Control Valve rebuild - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 10-18-2019, 01:55 PM Thread Starter
Tracs's Avatar
I rebuilt my H2 control valve. I searched the forum and didn't find any good pictures. I've attached some pictures of the valve and specific parts for future reference.
I changed the (4) o-ring seals. 2 for each spool shaft. I cleaned the detent ball bearings and groove. I installed a new lift check plunger and spring.
The disassembled parts are sitting on a old t-shirt. When I put it back together everything was kept super clean.
ID:	2401257   Click image for larger version
ID:	2401259   Click image for larger version
ID:	2401261   Click image for larger version
Tracs is offline
post #2 of 5 Old 10-18-2019, 02:20 PM
Red Cap Club
nick4030's Avatar
Re: H2 Control Valve rebuild
Cool thread! What was it doing to warrant a rebuild? Leaking I presume? We've did you get the parts?
2007 John Deere X748
1991 John Deere 332
1973 John Deere 140 H3
1973 John Deere 110
1974 Case 646
1961 Cub Cadet Original
nick4030 is online now
post #3 of 5 Old 10-18-2019, 02:29 PM Thread Starter
Tracs's Avatar
There were a few issues I had. One being it was popping out of the detent position. The other was the front quick hitch was drifting down when in the fully up position. That may or may not have been the valve. It might be the front cylinder. When the snowblower was full of wet snow it would barely lift off the ground. The valve itself had no external leaks.
Tracs is offline
post #4 of 5 Old 10-18-2019, 09:36 PM
wally2q's Avatar
so did it fix it?
wally2q is online now
post #5 of 5 Old 10-18-2019, 09:45 PM Thread Starter
Tracs's Avatar
Originally Posted by wally2q View Post
so did it fix it?
The detent position is fixed. I haven't had the blower on the front hitch to see how it handles it. I did have the hitch fully raised to see if it was drifting down. Like a dummy I hit the control lever and it dropped half way. But its been half way for 4 hours and hasn't gone any lower yet.
I did a mid stroke bypass test on the lift cylinder. At mid lift I removed the extend hose and gave it full retract and it didn't move even a fraction of a inch. That should mean the seals in the cylinder are good and there is no fluid leaking by.
I used this video as a guide.
Tracs is offline
You may post new threads
You may post replies
