Mechanical Help Removing Hydraulic Fitting - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 24 Old 10-15-2019, 09:19 PM Thread Starter
Frank@Mound's Avatar
Hi All -Been so long since I picked up my 54 snow blade for the JD 318 and haven't used it yet! I ordered the lockout valve from AuxHyd, have it at the ready but I am having trouble removing the hydraulic fitting from the rockshaft cylinder necessary for the new valve. Any tips on getting that bugger out without removing the cylinder? Picture of the offending fitting attached...
Thanks!
post #2 of 24 Old 10-15-2019, 09:40 PM
Smalljob's Avatar
Re: Mechanical Help Removing Hydraulic Fitting
I have done this on several machine without issue. Can you be more explicit? Are you unable to turn it because it won’t budge or is it that you are having difficulty getting a wrench on it?
1988 332 with 49 blower , 54 blade and 3 pt hitch
X500 w/48 deck and 44 blower
1023E H120 loader, B260 BH, 54D deck
Moved on to new home
1962 IH Cub Cadet Original
1963 110 Round Fender... Restored
1963 IH Cub Cadet 100, plow, deck, weigh box, 3 point hitch
1965 110 Round Fender with Model 38 deck..Restored
1966 110H Round Fender with Model 42 Blade..Restored
1967 112 Round Fender with Model 36 blower
1967 112 Round Fender with Johnson Model 10 Loader
1971 120 with 48 deck and 49 blower and OTC cab
1973 140H3 with 41 deck
1987 318 with 46 deck, 54 blade, 49 blower, 3pt hitch
1987 332 with 46 deck
Smalljob is offline
post #3 of 24 Old 10-15-2019, 10:59 PM
Steve Urquell's Avatar
Looks like the angle is difficult to get a combination wrench on. May need an angle head.
2001 Cub 3240 with fabbed hydraulic sleeve hitch and Swisher Hydraulic Front Bucket
Steve Urquell is offline
post #4 of 24 Old 10-15-2019, 11:11 PM Thread Starter
IT won't budge -AuxHyd said to douse it in some antisieze spray so I PB blasted it. They let me know it's a counterclockwise spin. To some degree it's tough to get a wrench in there or lack of motion due to transaxle housing
post #5 of 24 Old 10-15-2019, 11:14 PM Thread Starter
Certainly need a different wrench -I'll poke around for an angle head.
post #6 of 24 Old 10-16-2019, 03:08 AM
20,000 Posts & Climbing
Pull the pin on one end so that you can swing it down for a better angle.
TUDOR is online now
post #7 of 24 Old 10-16-2019, 03:26 AM
paul kellam's Avatar
It is certainly tight down there, I had to take the seat pan off of mine, I don't know if it helped that much but at least i could see better, don't forget the teflon tape, and happy plowing. it is amazing how much snow you can move with one of these blades.
paul kellam is offline
post #8 of 24 Old 10-16-2019, 03:44 AM
Paul & others: DO NOT USE TEFLON TAPE ON HYDRAULIC COMPONENTS. A liquid or paste type sealant is the recommended sealant for hyd fittings. Bits of tape can break off and go through the system. They can lodge in valve spools, pumps, motors, under seal lips, etc, and can destroy a component or the system. Some have gotten by by starting tape a thread or two back from the end of the fitting, others have not! Most auto parts stores carry the correct hydraulic sealants...USE IT! Bob
rwmeyer is offline
post #9 of 24 Old 10-16-2019, 10:16 AM
inspectorudy's Avatar
Do you have a "Crow Foot" set of open-end wrenches? That will give you a lot of different positions to try. I changed out at least two and I do not remember a left-hand thread. Of course, my memory isn't what it used to be either.
inspectorudy is online now
post #10 of 24 Old 10-16-2019, 11:13 AM
Agreed.
Starting a thread or two from the end is OK until you need to take it apart. Then the tape will shred and pieces will get in the system.
Zebra5 is offline
post #11 of 24 Old 10-16-2019, 02:45 PM
demonspeed's Avatar
I’d just grab it with small vice grips.
2004 John Deere GX345
48” Edge, Predtor2’s & Blowout Kit|42” Thrower
Front Bumper|Halogen Kit|Carlisle Xtrac & HDFT
FOR SALE: 48" Blade 3481M/BM19415, Angle Kit BM21341, and Attach Kit BM19218 for 200/300/GT/GX series
demonspeed is online now
post #12 of 24 Old 10-16-2019, 03:08 PM
Those angle fittings don't have really good flat areas for the wrench to grab. You need a nice, wide jawed wrench that fits tightly and is long enough for good leverage. In my toolbox the only thing that fits all those needs is a big adjustable wrench tightened down as far as possible.
I'd pull the pin on one end as suggested and put one of those on it.
antiqueetc is offline
post #13 of 24 Old 10-16-2019, 10:58 PM Thread Starter
Ok -I did this, thank you.
post #14 of 24 Old 10-16-2019, 10:59 PM Thread Starter
I used the "dope" sent with the Aux Hyd hoses and lockout valve. Their instructions were explicit on the teflon tape no-no.
post #15 of 24 Old 10-16-2019, 11:01 PM Thread Starter
I suppose its right handed if you are looking down, but I was laying down looking up! By the way, I found some crows feet in the basement and you know what -that did the trick (and did in my knuckles some)
