47 inch blower chute acuator - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 10-11-2019, 09:33 AM Thread Starter
Trying to decide if I want the electric chute actuator or the manual cable operated one from deere.Anyone with any experience with any of these?Im not crazy about taking my dash off my 738 to drill a hole to mount the switch.Thanks for your replies.
rhondale79 is offline
post #2 of 20 Old 10-11-2019, 09:41 AM
Re: 47 inch blower chute acuator
I have an actuator on my 345s 42 inch blower and like it. Replaced the original cable when it snagged and broke for half the money. On mine the switch is on the bracket that held the cable not the dash. Roger
ID:	2399731   Click image for larger version
rhenning is online now
post #3 of 20 Old 10-11-2019, 08:25 PM
jgayman's Avatar
I'm going on 6 seasons with the cable operated remote spout control and it still works fine and the cable and other components show no signs of wear. I've thought about upgrading to a linear actuator but those can freeze up the same as the cable (although I have never had my cable freeze up).
Sometimes the low-tech approach is just fine. :-)
jgayman is offline
post #4 of 20 Old 10-11-2019, 08:27 PM
jgayman's Avatar
If I were to ever upgrade to a linear actuator, this is the approach I would take as well. But then again, if you didn't start out with the cable operated control you won't have the bracket already installed. ;-)
jgayman is offline
post #5 of 20 Old 10-11-2019, 08:28 PM
gt275's Avatar
Doing the same thing on my gx345. I mounted the switch to the bracket as well. I have a cab so I could mount it almost anywhere I wanted, but the bracket made the most sense.
To the original poster, if you're going to keep the tractor for a long time, mount it to the dash so it works for you. Just be careful when drilling the hole. Or, get the rod that the cable mounts to and use that to mount the switch.
2004 X485 (4/15) 25hp Kawasaki, 62" deck, 45 Loader, Front-mount de-thatcher.
2005 GX345 (11/09 124hrs) 20hp V-twin liquid cooled Kawasaki, 54" deck, Differential lock, Femco Cab Weather Enclosure, 42" snowblower, Electric Spout Rotation Kit.
1998 345 (08/19 627hrs) 18hp V-twin liquid cooled Kawasaki, 54" deck.
-SOLD-
2001 345 20hp V-twin liquid cooled Kawasaki, 54" deck
1998 GT275 17hp Kawasaki, 48" deck, Cab Enclosure, 38" Snowthrower, Manual Spout Kit
1997 LX188 17hp Kawasaki, 48" deck
gt275 is offline
post #6 of 20 Old 10-11-2019, 08:38 PM
jgayman's Avatar
The problem with that approach is JD wants $104 for just the bracket. You can get the entire remote spout control kit for $129. The OP would probably be better off to get the remote spout control kit, use it until it breaks (which could be many years) and at that point use the bracket for the control switch. :-)
jgayman is offline
post #7 of 20 Old 10-11-2019, 08:43 PM
830King's Avatar
The only adjustment I have on my 46 is stopping getting off the seat and adjusting it manually . I was thinking about getting getting a electric one. They around $150 on Ebay if I recall.
Sent from my SM-G930V using Tapatalk
830King is online now
post #8 of 20 Old 10-11-2019, 11:28 PM
celltech's Avatar
Electric actuator all the way. Super easy install, no need to remove the dash. Just use a unibit to drill the hole.
2010 John Deere X720 w/ 48" deck and 47" snowblower
2000 Lawn Boy Silver 10323
1998 Lawn Boy Gold Pro 10547
1997 Lawn Boy Gold 10518
2014 Ariens Deluxe 28+ 921035- Sold
1989 Toro 824- Sold
celltech is online now
post #9 of 20 Old 10-12-2019, 04:20 PM
drano38's Avatar
The electric actuator works great. Controlling the chute is easy and precise.
I mounted my switch to the hydraulic lever. Wires come thru boot for the lever, so no holes drilled. See a link in my signature. Here's the pics since the links in the original post are dead.
https://www.mytractorforum.com/album.php?albumid=17451
Mine has never froze up, but my machine is in a heated garage.
2008 x729
Hard cab w/ heater,
54c deck, 47" snow blower, 52" broom, SE seat
JD 45 loader
Snowblower chute rotation modification
Snowblower deflector actuator modification
Deflector actuator pics
Cab removal setup
drano38 is offline
post #10 of 20 Old 10-12-2019, 05:16 PM
Actuators come in many size and sometimes speeds. I ordered mine based on the movement needed to move the chute. I have had zero problems with icing up. Paid about $60 on EBay. Could move a bit faster but there is no reason for it to do that when blowing and only adds one minute per hour of seat time. Roger
post #11 of 20 Old 10-12-2019, 07:09 PM
gt275's Avatar
Here is my set up on a 42" snowblower and gx345.
Just finished the install today. I may move it to the opposite side.
I bought the rubber boot cover for it too. Showing switch and waterproof 2 pin connector (BLK/Red wires).
Doesn't go as fast as I would like it to, but is fine. Way better than a cable.
ID:	2399937   Click image for larger version
ID:	2399939   Click image for larger version
ID:	2399941   Click image for larger version
-SOLD-
gt275 is offline
post #12 of 20 Old 10-14-2019, 11:06 PM
Gt275 can you give some info on your setup? Supplier? Part number(s)? Was it a kit? Thanks
Marshallgang is online now
post #13 of 20 Old 10-15-2019, 04:51 PM
FTWingRiders's Avatar
Mine froze a few times so I inverted it. Works fine, and hasnít frozen up on me yet!
Forrest
X748 2011 with 45 loader, 3PH, remote valve, rear hydro, 54" mulching deck, custom hard cab and R4's
455 with 48' deck with PF and Hydraulic tilt dump, 26" HDAP's, front 18" HDAPs on 10" wheels
John Deere Cab
54" deck
54" blower with metal Impeller, chute rotation and flapper mod, 36T sprocket.
Laded 26" HDAPs for winter duty
54" blade with extensions.
51" rotary broom
3 quick hitches
Front mount dethatcher
Titan forks
SOLD:425, X585
FTWingRiders is offline
post #14 of 20 Old 10-15-2019, 09:33 PM
gt275's Avatar
This was not a kit. Almost everything was purchased individually on ebay.
4" stroke Linear Actuator.
Used a 30 Amp momentary toggle switch and braided wire loom.
18ga wires.
2 pin waterproof electrical connector plug.
M6 x 1 - 65mm lg screws and 3/4" nylon spacers for mounting. 1/4" screws are too large for the actuator.
-SOLD-
gt275 is offline
post #15 of 20 Old 10-15-2019, 11:24 PM
drano38's Avatar
Marshallgang
Some of us pieced it together ourselves, others bought kits.
I pieced mine together.
Here's a link to the actuator that works well.
model FA-35-S-12-4 (35 pound force, 12 volt, 4" stroke)
https://www.firgelliauto.com/collect...near-actuators
And my signature has a link to an older thread on how several people did theirs, including switch mounting locations.
2008 x729
Hard cab w/ heater,
JD 45 loader
Cab removal setup
drano38 is offline
