332 rear weight bracket ideas - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 10-10-2019, 12:58 PM Thread Starter
Tracs's Avatar
JD suitcase weights and bracket are too much $ for me. So I’m gonna make my own setup.
I’m trying to come up with a design for a rear weight bracket for my 332. I got 4 free pieces of 100lbs railway rail that are 36” long. Rail that is stamped 100lbs is 100lbs per 36”, if it was 136lbs rail it would be 136lbs per 36”, and so forth.
I’m trying to decide if I should weld up a bracket that stacks the rail horizontally or vertically.
What are your thoughts on this?
Tracs is online now
post #2 of 20 Old 10-10-2019, 04:26 PM
Re: 332 rear weight bracket ideas
I would suggest horizontally, like a bumper, to have a lower center of mass.
dave_r is offline
post #3 of 20 Old 10-10-2019, 07:55 PM
Still lovin' the 322!
PA318Guy's Avatar
I agree with dave, low slung to keep your CG low.
Current Machine JD 322
PA318Guy is online now
post #4 of 20 Old 10-10-2019, 08:28 PM Thread Starter
Tracs's Avatar
So I've been scratching my head trying to come up with the best/most efficient use of space/style.
I came up with a couple ideas.
On the first one, the rail would slide in and fit secure into channels cut on either end. This style stacks the rail and would leave it 24-30" high.
The second one would be a platform/basket carrier. The rail would have 2 down low with one inverted in between them. The load would be down low.
Anyone have any critiques?
Tracs is online now
post #5 of 20 Old 10-10-2019, 09:23 PM
PA318Guy's Avatar
# 2 gives you a lower CG to work with, but # 1 looks more convenient to work with.
post #6 of 20 Old 10-10-2019, 09:42 PM
Rail is generally listed as lbs. per yard. So the average US mainline rail would be 130 lbs. with 3 foot of length.
Ariens93GT20 is offline
post #7 of 20 Old 10-10-2019, 09:48 PM
Yea that what your first post said. I had a no brainer moment. My vote is for option 2.
post #8 of 20 Old 10-10-2019, 10:04 PM
Parts collector
mopar65pa's Avatar
Personally I would line them triple front to back in whatever you come up with as a "hauler/bracket" and stack them as low as you can.
Just my .02$ though.
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is online now
post #9 of 20 Old 10-10-2019, 11:57 PM Thread Starter
Tracs's Avatar
I do have the hydraulic rototiller brackets on the tractor. I don't like how low they sit so I flipped them upside down to see if I could come up with anything to use them.
Tracs is online now
post #10 of 20 Old 10-13-2019, 07:15 PM Thread Starter
Tracs's Avatar
So I've been in the garage cutting and welding. I am going to use a modified version 1.
This is what I have so far. Some of it is modeled after the original JD suitcase weight bracket. There will be one 36" rail across the top behind the tail lights, and 2 mounted under it. The upper tiller brackets serve as a stabilizer.
Tracs is online now
post #11 of 20 Old 10-17-2019, 01:47 AM Thread Starter
Tracs's Avatar
I got some more progress done on the bracket. It didn't turn out exactly as I envisioned but it will certainly work. I am only into it for the equivalent cost of 2 JD suitcase weights.
I have to grind a bit more on the bottom holder so the rail slides in.
The bottom rail will sit above the lowest point of the tractor so ground clearance will not be a issue. I have to take the bracket off and do final welding.
This bracket will add 300lbs of rail plus the weight of the bracket which is about 50lbs.
I am going to paint the bracket black and the rail JD green.
Tracs is online now
post #12 of 20 Old 10-17-2019, 02:25 AM
Time to practice those plasma cutter skills.... :-) Nice job.
dave_r is offline
post #13 of 20 Old 10-17-2019, 02:27 AM Thread Starter
Tracs's Avatar
Oh yeah..It was brutal. Truth be told it was my first time using a cutting torch. I don't think I had things set right at all.
Tracs is online now
post #14 of 20 Old 10-17-2019, 12:35 PM
Merc1973's Avatar
Pretty cool design! Plasma cutters are fun.
1981 400- Vanguard 23 HP, 54C deck, 56 blade, 50 snow blower
SOLD-2003 G100- 54", Kohler Command 25, Gator G5 blades
JD 46" snow Blade
Stihl 031AV (WIMA cap, base gasket delete) 20"
Echo CS-590 (MM) 20"
Husqvarna 128LD Trimmer
Giant Vac w/ 6.5HP Predator Engine
Unknown 1980's Japanese backpack Blower with Kawasaki engine
1968 M35A2
Merc1973 is offline
post #15 of 20 Old 10-17-2019, 12:54 PM
inspectorudy's Avatar
Nice job but you must be strong to use such large pieces for weights. I can only imagine trying to line up and slide those big pieces into those slots! I have learned after two back surgeries that I will never lift any more than absolutely necessary. I make all of my rear weights easily detachable usually with a 3 ph. It looks like in your case it is a one-time thing since it is on your plow but for those of us who would remove and then reinstall the weights more frequently, that it would be a lot of work. I was wondering what the two bars going to your rock shaft do? I am sure they are not welded on to it. Are they just hooks?
inspectorudy is online now
