x360 Transaxle Leak - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 10-10-2019, 10:11 AM Thread Starter
Bakerman1949's Avatar
Angry x360 Transaxle Leak
My John Deere x360 has a small leak at the transaxle. When the transaxle was serviced 2 years ago, noticed a small leak afterwards. The dealer checked and re-tightened the lines. They told me at the time it should be good, but if it does return the only way, they can fix it is by removing the fender pan, and replacing the line, as the line that was showing leakage was on the top. The problem being that my OTC cab is on the tractor and would have to be removed. The leak stopped. A few weeks ago, the idler pulley for the drive belt burnt out. While the dealer was replacing it, I asked if they could check to make sure there was no further leaks. Service guy said he noticed a little oil, but he wiped it off. Since then I have a constant drip. Thatís the long short story. The QUESTION I have does the fender pan really need to come off to replace the upper line? I have just put the OTC cab back on and have rewired all the lights and wiper for winter. This was a long and involved process to get done and I really do not want to remove it again for any reason let alone to remove the fender pan. I was hoping this line could be replaced without that process. Might I add that when the original leak happen the tractor was still under warranty, that has since expired.
Thanks, sorry to be so long winded.
2013 x360 44" Snow blower,
OTC Cab with lights
48" Deck and Power Flow Bagger
2014 X530 54" Deck
Bakerman1949 is offline
post #2 of 3 Old 10-10-2019, 02:03 PM
jgayman's Avatar
Re: x360 Transaxle Leak
Which upper line are you referring to?
jgayman is offline
post #3 of 3 Old 10-10-2019, 03:06 PM Thread Starter
I am not sure, I cannot get under the unit, and they described it as the upper hydraulic line from the trans axle.
OTC Cab with lights
2014 X530 54" Deck
