50 Blower Questions - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 10-10-2019, 12:26 AM Thread Starter
Merc1973's Avatar
50 Blower Questions
Im in the process of repainting my 50 blower. It functions well, but I have yet to try it in snow. I need to remove the auger and following the the technical manual, i need to remove the drive gear off the shaft and key. Im having trouble removing it. Short of drilling holes to use a steering wheel puller, whats the best way? It does not seem rusty, just stuck. I soaked it in ATF/acetone mix and gave some love taps with a hammer so far...
Merc1973 is offline
post #2 of 12 Old 10-10-2019, 01:33 AM
10 fingers 10 toes
Kubota Ronin's Avatar
Re: 50 Blower Questions
Use a bigger puller with jaws that can grab the outside of the gear, apply some pressure and some heat to the gear... easy does it and a few more hammer taps to break the nature's seal.
Scott
Kubota AMX-3
Shibaura LT16B
Kubota Ronin is online now
post #3 of 12 Old 10-10-2019, 12:41 PM Thread Starter
Merc1973's Avatar
Thanks. Im scared to use a jaw puller and end up bending it. I suppose some pressure with the jaws and some rattling with the impact hammer might help...
Merc1973 is offline
post #4 of 12 Old 10-10-2019, 01:36 PM
Red Plaid is Timeless
grandpajay's Avatar
How about taking a large socket or stub of pipe and drive the sprocket on the shaft a little further-1/4” or so to break it free. Also wouldn’t take long to drill and tap a couple of holes. I’ve got quite a few small pieces of steel with 2 odd holes that I have made up through the years for quickie pullers.
grandpajay is offline
post #5 of 12 Old 10-10-2019, 01:45 PM
Wfburton159's Avatar
You have loosened the jam bolt correct? It is still in the hole in the photos is why I ask.
Wfburton159 is offline
post #6 of 12 Old 10-10-2019, 04:04 PM Thread Starter
Merc1973's Avatar
Thanks, good idea. I have some scrap metal I could play with...
HAHA, yes it's just sitting there by a thread or 2.
Merc1973 is offline
post #7 of 12 Old 10-11-2019, 09:07 AM Thread Starter
Merc1973's Avatar
It came off with the big 3 jaw puller and impact wrench. The cog is pretty stout. Not much rust But looks like hardened grease.
Bearings were toasted after knocking them off with the impact hammer. Time for new ones. I was wrestling with the auger last night for an hour. It's quite heavy, it still wont slide out. The tractor originally lived at a house with gravel driveway. You can see just by looking at the mangled auger edge and pitted housing. There has been prior repairs to bent auger with welding on long bolts along cutting edge.
Merc1973 is offline
post #8 of 12 Old 10-11-2019, 10:20 AM
grandpajay's Avatar
Your challenge now will be to get the shaft loose that is inside the auger tube. You'll have to get it one direction or the other to get the auger out of the housing. You might have to throw some heat on it. Good luck!
I probably should have sandblasted mine whilst apart but just sanded it, cleaned up the rust, and used POR15 for priming. My thrower is even better at leveling the gravel driveway than my land plane.
If I'm not careful-this could be me-only blowing snow.
https://www.ispot.tv/ad/7Lqz/allstate-mayhem-lawn-game
ID:	2399737   Click image for larger version
post #9 of 12 Old 10-11-2019, 12:36 PM Thread Starter
Merc1973's Avatar
That Mayhem commercial looks about right!
Great resto on the 50! I will remove the shear bolt to see how badly stuck it is. Ordering some Timken RA100RRB bearings. I didn't realize how deep I was getting myself into until last night. So much for a quick sand and paint job... Its' snowballing just like when I resto'd the 400
Merc1973 is offline
post #10 of 12 Old 10-11-2019, 05:13 PM
Still lovin' the 322!
PA318Guy's Avatar
Got to love those Mayhem commercials!!! Really overall not too bad, augers always take a beating so some bending is really pretty normal. I agree getting the long shaft out takes the most effort. Get the curse jar and a big hammer/sledge out!
Current Machine JD 322
R.I.P to my Wife Joanna, 36 Years of Marriage!
PA318Guy is online now
post #11 of 12 Old 10-14-2019, 08:27 PM Thread Starter
Merc1973's Avatar
Auger and shaft are out. Only 10 min of twisting and pulling it out. Gave it one starter nudge with the mini sledge, thats it. I lucked out. I plan on cleaning the shaft with wire wheel and slathering it in grease, maybe some antiseize on the ends. Is this the preferred method?
The Auger has seen better days. In the one pic you can see all the rocks that fell out when first removal of the panels.
Merc1973 is offline
post #12 of 12 Old 10-14-2019, 11:22 PM
grandpajay's Avatar
Wire wheel and grease was how I fixed up the shaft. I don't remember if I tried to run something through the tube. I might have used a rod and some steel wool. That's the advantage of getting older-I can imagine how smart I used to be. My wife might disagree.
You may post new threads
You may post replies
