Rip HD 400 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Unread 10-07-2019, 04:39 PM Thread Starter
JollyRancher's Avatar
Rip HD 400
Changed out starter other day and all a sudden it stopped working again...bit this time with sparks... took off the shields to check it out and saw the oil pan casting that hold the starter true cracked... and cant seem to find one anywhere...so now it's time to check out my options and table the 400 till I can find a new oil pan... maybe time for stop over at the local jd dealer...
Sent from my SM-G930V using Tapatalk
Current Lawn Mowers:
Craftsman 917.270940--current grass killer
Yard Pro y2050b--collecting dust
Past Lawn Mowers:
John Deere 185 hydro
JollyRancher is offline
post #2 of 13 Unread 10-07-2019, 04:41 PM Thread Starter
Re: Rip HD 400
JD NOT HD
Cant find the edit button
Past Lawn Mowers:
post #3 of 13 Unread 10-07-2019, 05:18 PM
Kish JD 318/420/430
RussKish's Avatar
Re: Rip HD 400
You can look on line for good/used oil pan for the Kohler. Check Ebay, Amazon, LGT Bone yards.
Russ
Proud Owner of: 318/420/430
RussKish is offline
post #4 of 13 Unread 10-07-2019, 05:39 PM
inspectorudy's Avatar
Re: Rip HD 400
Here's a P224 pan on eBay. What you need to do is when you see an Onan ad for parts, go to the seller's site and he will probably have a pan that he isn't advertising. That's how I found this one.
https://www.ebay.com/itm/JOHN-DEERE-...IAAOSwxsRdBrT9
inspectorudy is online now
post #5 of 13 Unread 10-07-2019, 06:00 PM Thread Starter
Re: Rip HD 400
I've checked ebay and amazon and added my searches to my notifications if any items get posted....I'll find one someday
Past Lawn Mowers:
post #6 of 13 Unread 10-08-2019, 12:47 PM
Merc1973's Avatar
Re: Rip HD 400
JB weld? I changed on on a JB Welded crack engine block of a Mercedes 300se. My current Yukon's transfer case has a JB Weld repair. No leaks on either.... I should last longer than the rods on that old tired Kohler.
1981 400- Vanguard 23 HP, 54C deck, 56 blade, 50 snow blower
SOLD-2003 G100- 54", Kohler Command 25, Gator G5 blades
JD 46" snow Blade
Stihl 031AV (WIMA cap, base gasket delete) 20"
Echo CS-590 (MM) 20"
Husqvarna 128LD Trimmer
Giant Vac w/ 6.5HP Predator Engine
Unknown 1980's Japanese backpack Blower with Kawasaki engine
1968 M35A2
Merc1973 is online now
post #7 of 13 Unread 10-08-2019, 01:46 PM
Re: Rip HD 400
I know the area he is talking about and nothing short of a weld will work. There is enormous pressure on that bolt/web and not only does it hold the starter motor but has to take the torque of turning over the engine. It can be welded by a good aluminum welder for about $20.
post #8 of 13 Unread 10-08-2019, 02:50 PM Thread Starter
Re: Rip HD 400
Is it aluminum? I for some reason thought cast iron...maybe I'll take it out and go to the tig man
Past Lawn Mowers:
post #9 of 13 Unread 10-08-2019, 03:23 PM
Merc1973's Avatar
Re: Rip HD 400
Rudy is right, Im not familiar with that part so Rudy's suggestion would be best.
JD 46" snow Blade
1968 M35A2
post #10 of 13 Unread 10-09-2019, 08:27 AM
Wfburton159's Avatar
Re: Rip HD 400
Do you know what you are looking for? You have the original Kohler engine correct? Kind of confusing when there is links provided to Onan parts and talk of Onan parts.
2003 John Deere X485
647 tiller
54c deck w/ mulch kit and power flow bagger
75# wheel weights and chains
John Deere 14SB
Wfburton159 is offline
post #11 of 13 Unread 10-09-2019, 11:26 AM
Re: Rip HD 400
You are right! I've had two 400's and two 420's and was thinking of the Onan in the 420. I haven't looked for the Kohler but I do know a guy with two of them for sale. He also has a completely rebuilt Kohler engine that hasn't been run since it was built 12 years ago. I can give you his e-mail address if you will pm me.
post #12 of 13 Unread 10-14-2019, 02:53 PM Thread Starter
Re: Rip HD 400
Things are looking up... found an oil pan on ebay will have is soon... now to find some odds and ends P.O. took off that I have found....1 is a belt "guide" on the front pulley on the motor right side... and other is some L shaped bracket that goes to a bolt on the back of the starter...
Side note anyone else hate looking through parts illustrations to find stuff?
Past Lawn Mowers:
post #13 of 13 Unread 10-14-2019, 02:54 PM Thread Starter
Re: Rip HD 400
Almost forgot picture... Click image for larger version
Past Lawn Mowers:
