Snowblower storage thoughts - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 17 Old 10-02-2019, 02:19 PM Thread Starter
I've seen various folks over the years show off their snowblower storage strategies. When it's time to change seasons, usually wind up raising mine up off the garage concrete floor with a few pieces of wood. I've seen folks use pallets. I'm looking for a better solution for the 47" blower on my x534. Thanks!
x534 with 54" deck (2012)
Mulch kit/striping kit/PowerFlow bagger
47" snow blower, suitcase weights, traction belts
25 gallon tractor mounted sprayer
54" Front mount dethatcher w/hydraulic lift mount by dternus
Sunshade
SOLD - 40" tractor shovel
RGrizzzz is offline
post #2 of 17 Old 10-02-2019, 02:51 PM
Jack of All Trades Guru!
Bassguitarist1985's Avatar
Re: Snowblower storage thoughts
I do mmy 42" SS on pallets in the backyard inside one of those Shelterlogic sheds. Keeps the water off it and works well. Sadly I dont have enough room in the two bay garage to keep it stored. I spray it down with lithium grease to prevent rusting, its been good to me for the 5 years I have had it.
Sent from my SM-N910V using Tapatalk
Bassguitarist1985 is online now
post #3 of 17 Old 10-02-2019, 02:56 PM
UpstateTony's Avatar
Easy keep mine on a harbor freight dolly. Keep it in my shed in summer, I have to get something and snowblower in the way, just roll it out of the way ( in fact even wife can move it) when it comes time to put snow blower on, just roll it into position, drive tractor up to it and snap it on snowblower front bracket-- takes all of 5 min for me to put snowblower on my X590
https://www.harborfreight.com/18-In-...lly-63098.html
2012 John Deere X310
2009 John Deere LA-135 SE
UpstateTony is offline
post #4 of 17 Old 10-02-2019, 03:04 PM
I use the harbor freight dolly approach too. Cheap, effective, and it's so much easier to get it back in the corner of the shed for the summer
TWG1572 is offline
post #5 of 17 Old 10-02-2019, 03:56 PM Thread Starter
Does the HF dolly slide under the blower when it's lifted all the way up? I know the height of the blower isn't amazingly high in it's fullest height position?
Sunshade
RGrizzzz is offline
post #6 of 17 Old 10-02-2019, 04:09 PM
My blower will clear the dolly. I have a 116, w/ a single stage blower.
I guess worst case scenario, you could always drive the front wheels up on a 2x4 or something to get a bit more clearance.
TWG1572 is offline
post #7 of 17 Old 10-02-2019, 04:13 PM
Professional Homeowner
steddy's Avatar
Mine is on a pallet. Could add wheels I guess, but I have a pallet jack that works. I touch up any areas where paint is gone... paint is NOT pristine after probably 30 years. Iíve only had it for one year now though. Lite or sili spray contacting surfaces (chute rotation). Grease all fittings. Store inside.
steddy is online now
post #8 of 17 Old 10-02-2019, 04:49 PM
https://www.harborfreight.com/materi...ly-69566.html: says its 5 1/4" high. The other ones HF sells are similar. Isn't the lift height of the 47 snowblower only 4"? You would probably need to drive up on blocks then.
They sell smaller casters, https://www.harborfreight.com/materi...ter-41519.html, you could replace the 3" ones on that dolly and that might get you to the right height?
winkeldc is online now
post #9 of 17 Old 10-02-2019, 05:46 PM
jgayman's Avatar
Check this out. Superior Tech recently came out with a pair of dollies for the 47" and 54" JD blowers. I bought a set for my 54" blower and they work great. They take up a lot less room compared with the wood platform with casters I was using.
jgayman is online now
post #10 of 17 Old 10-02-2019, 08:28 PM
JoeZeppy's Avatar
My situation is a little bit different since I have an LA-series so the blower has arms that attach about mid-tractor. I also built a dolly from scrap 2x4's and some casters I had laying around but I have to block up the blower about 5" once it's off the tractor and then tilt it 90* up on to the dolly so the arms stand straight up. Easy to move into a corner of the garage.
2008 John Deere LA165: 24hp, 48" deck, 44" snowblower
1994 MTD 8hp/26" snowblower
Rubbermaid/Craftsman poly dump cart
K-mart 22" push mower
2010 GMC Sierra 2500HD
2014 Subaru Legacy Sport
JoeZeppy is offline
post #11 of 17 Old 10-02-2019, 08:43 PM
blinged out
donmac's Avatar
I take the chute off the 44" and strap it standing up on a 2 wheel dolly, can move it anytime easily!
donmac is offline
post #12 of 17 Old 10-02-2019, 10:03 PM Thread Starter
These look perfect, but $100?!?!?!
https://www.greenpartstore.com/John-...s-LP70692.html
Sunshade
RGrizzzz is offline
post #13 of 17 Old Yesterday, 07:29 PM
I use the wooden harbor freight dolly too, just fits under the 47 blower while still attached to my 318. Lines right up, it’s perfect<img src="https://www.mytractorforum.com/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
CT318 is offline
post #14 of 17 Old Yesterday, 10:24 PM
Proud JD Owner
Mach-1's Avatar
I made a dolly for my for my 54". Not a big deal. Makes it easy to store and re-connect when you need it.
___________________________________
2008 X720 Ultimate
54" Blade
47" Snowblower
Powerflo Bagger
Mulch Kit
#18 Dump Cart
Mach-1 is offline
post #15 of 17 Old Today, 06:49 AM
c5rulz's Avatar
Me too.
Buy some decent casters and make a dolly. Easy to put on and off and roll into the corner for storage.
JD X758 60" HC deck
Dolmar 7900
Jonsered 2159 ported
Echo CS303T
Echo PPT 266
Echo PPT-266 pole saw
Silvey 510
Oregon 511AX
Nielsen 100B for rakers
c5rulz is offline
Fishwater2002
