X590 PTO engagement question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 09-20-2019, 08:28 AM Thread Starter
I just picked up a new x590 and noticed that when engaging the PTO, it's not immediate. I pull the engagement switch and then there is a half second-second delay before the PTO actually engages. It definitely is not immediate. I know that doesn't seem long, but its electronic (isn't it?), I would assume its like trying to run inside a room before the lights go on after hitting the switch? My last machine didn't do that, it was almost immediate. I assumed it was okay because it did that consistently the entire time I mowed, so not like it was sporadic or anything. But, before I ask the dealer about it, I thought I would see if anyone else out there has noticed this or if its just a quirk with the PTO clutch.
I only have one picture . . .
winkeldc is online now
post #2 of 5 Old 09-20-2019, 08:32 AM
AKA Moses Lawnagan
KHodges's Avatar
Re: X590 PTO engagement question
Sounds normal to me. 1/2 second is about as close to immediate as you can get. Pull the switch, relay closes, PTO starts to spin.....
'09 JD 2520, CX200 loader and 62D deck
LP RTR0550 rototiller
?? 60" box blade
3-point PTO DR wood chipper
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
'86 JD 212, 38" deck
'08 X748SE, gone but not forgotten
KHodges is offline
post #3 of 5 Old 09-20-2019, 09:02 AM
UpstateTony's Avatar
That is perfectly normal- according to your manual the PTO should be engaged at full throttle. When you engage the PTO the electric clutch ( brakes for blades) must be released and then PTO engages, that is one of the reasons for the slight delay you are experiencing. The electric clutch is what stops blades from turning when you disengage the PTO-- otherwise blades would take quite some time to stop turning
2012 John Deere X310
2009 John Deere LA-135 SE
UpstateTony is offline
post #4 of 5 Old 09-20-2019, 09:28 AM
wirlybird's Avatar
Send a message via AIM to wirlybird Send a message via MSN to wirlybird Send a message via Yahoo to wirlybird
My X585 is like that. Pull the PTO and a second or two and then a nice smooth engagement.
I think you are good.
wirlybird is offline
post #5 of 5 Old 09-20-2019, 09:48 AM Thread Starter
Thanks all! It was one of those things that when doing something and it gives you time to think, well you overthink it.
