I have a x758 for2 years now. I have the 54 HC drive over deck manual PTO hookup. From the dealership, I had mulch control kit (bm26300) installed new.
It never has seemed to work quite right. The gate would creep open halfway frequently. Last night I got annoyed enough to take the deck off and get a good look at it. It wasn't making sense how it was installed so I looked up the installation instructions and found it wasn't installed correctly. The piece with the F stamped on it was upside down and instead of two bolts holding it on only one was used. The bolt with the square shaft wasn't going through the hole on the bracket. Instead, it was beside it. That explains why it hasn't worked correctly!!! :tango_face_surprise
Anyways the handle has a square hole in it which is no longer quite square. Is their an individual part number the handle?
Also, does anyone have the complete install manual as a pdf? I went to the JD link which has links for individual pages.
Thanks
Thanks
