JD 445 will not start - no spark - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 09-18-2019, 10:06 PM Thread Starter
It's a 1993 JD 445 that won't turn over anymore. It started fine a few days ago when my son took it out to cut for about 5 minutes. I've had the tractor about 15 years now and maintain regularly.
I've checked other posts on this issue and have tried a few of the suggestions. Here's my issue:
1. turn key, console lights up so battery is good, when middle light goes off, turn key further to start it. It makes a fairly loud steady sound as I turn the key, like it's trying to fire but doesn't.
2. I checked the plugs and there is no spark. I replaced the plugs and still no spark. Oh yeah, when I try to start it, it backfired on two attempts, so fuel is getting there.
3. the seat safety switch was okay, but I bypassed it anyways and still no spark.
4. I always use premium fuel. I also changed the air filter as part of my maintenance.
What's next? The brake has to be pushed in to start it. Is there a safety switch somewhere that is associated with the brake pedal? The PTO switch is fine.
serial # is M00445A011748.
Thanks a bunch
rocksoldier is offline
post #2 of 14 Old 09-19-2019, 06:59 AM
Re: JD 445 will not start - no spark
Not familiar with this machine. But if it has a coil I would definitely test it or replace it.
Sent from my SM-N975U using Tapatalk
robs9 is offline
post #3 of 14 Old 09-19-2019, 07:44 AM
Rock, Check + side of coil to ground while cranking engine and you should see 12 volts. If none, bad wire or ignition switch. Then check - side of coil to ground. I believe (??) you should see 7-9 volts, then to 0 volts, back to 7-9. If you have this, coil is good and points are good. If no voltage, remove wire & condenser from - side of coil and check again for voltage. If voltage, coil is good, wire to points or condenser, or points bad. If 7-9 on - side of coil, replace wire from coil to plug. Bob
rwmeyer is online now
post #4 of 14 Old 09-19-2019, 09:31 AM
Kish JD 318/420/430
RussKish's Avatar
The 445 tractor engine is EFI and full electronic ignition using pulser pickups with an electronic brain called the ECM (marked as Fuel Injection Control Module)
Russ
Proud Owner of: 318/420/430
RussKish is online now
post #5 of 14 Old 09-19-2019, 11:49 AM
inspectorudy's Avatar
Check the two LED's on the PCB and see if they are both on. If not it will never start. Search for the remedy to getting both lights on. It has been discussed many times here. It is probably one of the safety switches out of adjustment. The two pedals are usually the culprits and moving either one up or down a tiny bit will usually solve the problem.
inspectorudy is online now
post #6 of 14 Old 09-19-2019, 07:37 PM Thread Starter
All three lights on the PCB light up strong, with the middle light staying on for 2 seconds after turning the key. If the two outside lights on the PCB are the test for the neutral safety switch, then it's not that switch right? And since lights are strong and I can turn on the headlights, battery and cables are good right? It's not the seat switch because I jumped it.
Old 09-19-2019, 07:38 PM
rocksoldier
This message has been deleted by rocksoldier. Reason: error
post #7 of 14 Old 09-19-2019, 07:40 PM Thread Starter
Hi Russ, does that mean there are specific tests I should be doing / not doing? Thank you
post #8 of 14 Old 09-19-2019, 08:08 PM Thread Starter
My bad, I was talking about the lights on the dash. As for the PCB, I just checked and I get both the green and red light on when I press on the brake to start it.
post #9 of 14 Old 09-20-2019, 01:58 AM
Did you play with the two pedals? Set the brake and then turn the key to start while lifting the reverse pedal a tad and then pushing down on the go pedal a tad. If it is one of the two pedal position switches then it will start.
post #10 of 14 Old 09-20-2019, 09:09 AM
Kish JD 318/420/430
RussKish's Avatar
Do you have the TM1517 for that model L&G tractor? Check your PM on this forum.
Russ
post #11 of 14 Old 09-21-2019, 03:15 PM
Jimbochap's Avatar
Cam gear ever been replaced?
John Deere X495
54" Mower Deck
Front Hitch w/ 54" Snowblade
Buford Bucket
Click N'Go Bracket
Rear Weight Bar
6 Suit Case Weights
Cast Iron Rear Wheel Weights
JD 345 SOLD
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Jimbochap is offline
post #12 of 14 Old 09-21-2019, 04:12 PM Thread Starter
Update for everyone. It is the camshaft!
post #13 of 14 Old 09-21-2019, 04:21 PM
mowergene's Avatar
How many hours did you get on the plastic? 1993 was a long time ago!
In the past:
In use:
mowergene is online now
post #14 of 14 Old 09-29-2019, 12:51 PM Thread Starter
Cam gear now changed.
I got over 1400 hours on the plastic cam gear. That's really good. The new one is steel, so won't be the next part to go!
